Get rid of any connection involving that T piece!  The boost T goes in a single (cut, of course) hose between the boost source and the wastegate actuator.  That other T is leading off into the wilderness, and is causing you to have no idea where the boost signal is being lost.  Just pull the T connections apart and block everything other than your connections to the boost T.
Ok i will get rid if the t piece. Switch one do i have the other end of the boost control go to? The white circle or the black circle? And do i just block the other one off or just leave it with nothing? Sorry for the dumb questions
See my recent setup diagram and follow that plus above and you’ll be right.
Ok so i would just attach the vac line that is in white direct to the boost controlller and then just block off that other line or leave it open?
Thanks mate
Hey mate,
I think this may work. I'll summarise briefly:
- Turbosmart BC piece will have to ends connected; one goes to the Wastegate actuator port and the other to the Turbo's boost port (located along the throttle body). So if you have any other connections left, it ought to be blocked off completely as at the moment it's going back into your stock boost solenoid. Also check all clamps and ensure there is no leakage anywhere...check AFM too and air intake too.
- Once you correctly hook everything up. Turn the car on and led it idle for around 10 minutes for the ECU to recognise the changes - this may do nothing but I've always done this to give the car a chance to accept changes and it's never harmed anything so you may want to give it a shot nothing to lose then take it for a drive and see what happens?
If this doesn't work then there's something more sinister at work here so you.re better off taking it to a mechanic.
Good luck mate.
Image result for r33 gtst turbosmart manual boost controller
  • Thanks 1
Thanks mate, will give this ago. Im probaby thinking it will have to go to a mechanic as well. I was hoping to avoid that because im kinda broke after the manual conversion.
I have checked and cleaned afm before because thats what i tried first. Also changed coils and sparks as well.
Fingerscrossed this works.
Good luck mate. I understand playing around with cars is a bottomless pit.
If the problem is if this doesn’t fix it it may be something that’s damaged so you will have to take it to a shop to avoid further damage.
7 hours ago, Robocop2310 said:
Hey mate,
Good luck mate.
Thanks mate, i will show you want i have done before i test it. I hope the photos arent confusing.
The  2rd and 3rd are of the turbo tee. Waste gate to tee and i couldnt find anyother line down there so that has to be for the turbo that other line near the waste gate? Anyway thats connected to the turbo tee.
I blocked off the sononoid.
I blocked off the tee piece that was going back from the turbo to the intercooler.
Also that line that is coming from the throttle body is already connected to something else (first picture)
Edited by TaylorS
The first 2 are of the turbo tee. Waste gate to tee and i couldnt find anyother line down there so that has to be for the turbo that other line near the waste gate? Anyway thats connected to the turbo tee.
Also that line that is coming from the throttle body is already connected to something else (last picture)20181029_093000.thumb.jpg.044c3d994bf0f1794a8f2e696dc12927.jpg
Hey mate, I cannot make our exactly what’s what from your photos but the one end needs to go to the throttle body for boost pressure as mentioned above so I don’t understand why it’s not hooked up and where else it’s going.
Follow it with your fingers and see where it goes?
  • Thanks 1
2 minutes ago, TaylorS said:
Ps. Irgone my edit the photo order kept charging so i changed where wach photo is.
1st two photos are turbo tee.
Last photo is throttle body
Please confirm exactly where the two tubes on the side of the MBC (manual boost controller) are connected to?
  • Thanks 1
Hahah sorey mate, everytime i reload this page the order of photos keep changing. This is the photo of where the 2 lines are going to off the manual boost controller
Make sure you blocked off everything else these two connectors look good.
Fire her you and let it idle for 10 minuites then take for a drive to test.
Good luck mate!
  • Thanks 1
Good luck mate!
Thanks mate, will give it ago. Should i adjust the manual boost controller or is the setting its on good? (Turned all the way anti clock wise) with one click clock wise)
Hey guys, still no luck :/ looks like i will just have to bite the bullet and take it to a shop hopefully this week.
I did however notice something. When i get to 3krpm ans the boost kicks in until it hits just under 4k rpm. When i hit the 4k rpm the car does a loud pop noise from the exhuast (this is just as thr boost cuts out) and  the check engine light comes on for about 2 to 3 seconds and then turns off again.
Thanks guys for all the replys
The new photos are wrong.
Somehow you have hood the boost T up between the wastegate actuator (which is correct) and the vent line back into the turbo inlet (which is VERY wrong).
You now have absolutely NO boost control.
The loud pop at 4k is when your car is hitting boost cut.  The ECU is killing it.
The boost T's second side needs to be connected to the nipple on the turbo outlet.  That's either on the turbo outlet pipe (to the intercooler) or directly on the compressor housing (there are a couple of options depending on the car - Nissan did it both ways).
Thanks mate i will try that. I can see the one your talkong about that goes from the tirbo outlet pipe so i will connect the turbo boost tee to that on the turbo side nip.
Where does the turbo inlet vent line go to?
Hey @GTSBoy and  @Robocop2310 thank you so much for your help. It turns out the vacuum lines were all wrong. I connected the turbo outlet pipe vac line to the boost tee and just blocked off the turbo inlet vent line off and the car seems to run perfect now. It still seems like the boost kicks in around 3k but it doesnt cut out anymore and feels much smoother.
GREAT WORK!!! Happy ending.
  • Thanks 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
