Boosted Esky Posted December 11, 2018 Share Posted December 11, 2018 (edited) Hi , first time post here. I have a 2.0L 8 valve SOHC motor (pinto) on E85 with 630cc injectors GT2860RS 0.86 turbo External WG (flapper welded shut) Haltech ps1000 making 301whp at 5800rpm 20psi. Power bug has bitten and I'm chasing another 40whp to hopefully crack into 11sec 1/4 mile. Because my hotside is custom it will be costly to change to T3 manifold and Vband dump etc so I've looked at the GTX gen2. It's rated at 475 crank hp, 115hp higher than the GT version. The only difference between the two is the billet compressor wheel and cover and the shaft speeds on compressor map are 35,000rpm higher. Is it foolish to think this could make 340whp? I'm trying to decide on this or GT30 , if the GTX2860R GEN2 can do it I'll stick with it. If anyone can vouch for this turbo making those numbers please chime in . Thanks Edited December 11, 2018 by Boosted Esky Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/ Share on other sites More sharing options...
Leroy Peterson Posted December 11, 2018 Share Posted December 11, 2018 I'm not familiar with the engine or what it can flow/handle, but the GTX gen1 or gen2 is a significant step up from the GT series. Much bigger/better compressor map suited for higher boost. If your setup can handle 20psi of a gtx28 turbine, I think you'll see a noticeable improvement. The compressor housing is quite a step up compared to the GT in size, but looks like you've got the space for it I went from GT2871 to GTX2867 gen1 years ago and very happy with the results. Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7893594 Share on other sites More sharing options...
Boosted Esky Posted December 11, 2018 Author Share Posted December 11, 2018 (edited) Thanks very much Leroy. The engine is fairly well built. ARP bolts throughout, Cosworth YB steel rods and YB pistons. Cometic MLS head gasket. Sounds like I should wind it up Edited December 11, 2018 by Boosted Esky Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7893600 Share on other sites More sharing options...
Dale FZ1 Posted December 11, 2018 Share Posted December 11, 2018 2 hours ago, Boosted Esky said: The engine is fairly well built. ARP bolts throughout, Cosworth YB steel rods and YB pistons. Cometic MLS head gasket. Sounds like I should wind it up Would be an interesting little package. No desire to go with a complete YB engine for cylinder head flow efficiency? 2 valve Pinto head would be a sticking point in chasing hp if you got really serious. By sticking with existing manifolding / turbine / wastegate you're definitely making life easier with the change over. Boost would be the preferred way to more hp than revving the engine harder IMO so the thinking is fairly sound if you're wanting a 40-50hp increase. Be interested to see the before/after results of this upgrade. Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7893630 Share on other sites More sharing options...
Boosted Esky Posted December 12, 2018 Author Share Posted December 12, 2018 Hi Dale. A YB cosworth head would be ultimate but would've added about 7 to 8K to my build cost. In standard form the YB head doesn't flow that great so porting, bigger valves, better cams etc. The factory brake booster would have to be deleted and bias pedal box installed with remote reserviors etc. The aluminum YB heads are also known for going soft and cost about 3k to harden if a suss one was purchased. The going rate for a standard used YB head in GC is about 3k. I was also keen for a challenge to do something different and it's been a whole lot of fun since having it on the road. PB at the drags is 12.7 114mph so hopefully can get a high 11 with another 40hp. Thanks Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7893639 Share on other sites More sharing options...
Boosted Esky Posted December 12, 2018 Author Share Posted December 12, 2018 Correction- a standard YB head is good for up to 380whp before porting & cams is needed. Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7893733 Share on other sites More sharing options...
Boosted Esky Posted September 6, 2020 Author Share Posted September 6, 2020 (edited) On 12/12/2018 at 9:51 AM, Dale FZ1 said: Would be an interesting little package. No desire to go with a complete YB engine for cylinder head flow efficiency? 2 valve Pinto head would be a sticking point in chasing hp if you got really serious. By sticking with existing manifolding / turbine / wastegate you're definitely making life easier with the change over. Boost would be the preferred way to more hp than revving the engine harder IMO so the thinking is fairly sound if you're wanting a 40-50hp increase. Be interested to see the before/after results of this upgrade. With a second Bosch 044 installed the GTX2860R genII made 355whp at 26psi. Car ran 11.7@ 121MPH a month ago Edited September 6, 2020 by Boosted Esky 4 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939636 Share on other sites More sharing options...
Boosted Esky Posted September 6, 2020 Author Share Posted September 6, 2020 (edited) .. Edited September 6, 2020 by Boosted Esky Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939642 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 6, 2020 Share Posted September 6, 2020 Power wise with that GTX2680R Gen 2 you're about right there on the limits. Best I squeezed out with a car I tuned a few months back was 274kW 1 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939662 Share on other sites More sharing options...
Boosted Esky Posted September 7, 2020 Author Share Posted September 7, 2020 Yep it's at its peak for sure ?. The tuner was happy to leave it at 355. It's a great turbo gives a near vertical power curve between 4000 and 4750rpm 1 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939671 Share on other sites More sharing options...
Boosted Esky Posted September 7, 2020 Author Share Posted September 7, 2020 1 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939672 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 7, 2020 Share Posted September 7, 2020 Good for baking tyres, luckily the SR20 I tuned still had its VCT functional, allowing some what less of a vertical power graph haha Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939676 Share on other sites More sharing options...
GTSBoy Posted September 7, 2020 Share Posted September 7, 2020 Needs an SC14 bolted on to fill the bottom end. Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939678 Share on other sites More sharing options...
Boosted Esky Posted September 7, 2020 Author Share Posted September 7, 2020 (edited) Yep normal road tyres will light up at highway speed if I step on it. My A048 semi slicks have really good grip with minimal wheel spin. Edited September 7, 2020 by Boosted Esky Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939685 Share on other sites More sharing options...
Boosted Esky Posted September 7, 2020 Author Share Posted September 7, 2020 3 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939686 Share on other sites More sharing options...
Roy Posted September 11, 2020 Share Posted September 11, 2020 LOLs, its making the same as my T38 on the YB in my Cossie...i really need a new hair dryer for the old girl. Your setup is bang on what I want to piece together in a MK 1 Cortina. Looks a m int intall. Did you do the abrication? 1 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939910 Share on other sites More sharing options...
Boosted Esky Posted September 13, 2020 Author Share Posted September 13, 2020 (edited) On 12/09/2020 at 9:25 AM, Roy said: LOLs, its making the same as my T38 on the YB in my Cossie...i really need a new hair dryer for the old girl. Your setup is bang on what I want to piece together in a MK 1 Cortina. Looks a m int intall. Did you do the abrication? Yes turbos have come a long way since the old tech T3's and T4's. I was in disbelief at the dyno seeing the result. Super happy with it. Thanks very much.. here's a more recent pic The turbo manifold & dump pipe were made by Dan @ Go Pipes and the aluminium intercooler pipes, turbo inlet & BOV return pipes by Silke Fabrications. Edited September 13, 2020 by Boosted Esky 4 Link to comment https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/#findComment-7939981 Share on other sites More sharing options...
