Hi all!
*** 2K for the lot ***
Garage Clearance Time
If no photos of what I have described, just ask.
Just sick of timewasters so take the lot for 2k!
6 x Denso 195500-2240 Injectors
1 x JR Pod Filter
4 x Jecs A46-00 Injectors
1 x Nissan RB26 block
1 x Universal Catalytic Converter 2 & 3 way – 5.9L / 6000LBS – 4” Round / 11” Long / 3” Ends
5 x New CP Piston Rings CPN-3406
50 x Oil Filters
1 x Microtech LT-8s Sequential Fire Ver. 10 ECU
2 x Garrett Turbo 466071-6C (stock off an R33)
1 x Power Distribution Block 1x0GA into 4x4GA
1 x Jecs MAF Mass Air Flow Meter A36-000 N62 / 22680 30P00
1 x Malpassi Fuel Injection Regulator
1 x R33 Twin Turbo Pipe
1 x SX Performance Fuel Regulator 15404
1 x Nissan ECU A11-000 RG3 - S13
1 x Nissan ECU A11-000 G90 - S13
1 x Set of 6 CP Carrillo forged Pistons suit RB30/26
1 x SR20 Crank Shaft 60J40
1 x SR20 Red Top Block
1 x SR20 Black Top Block (non VCT)
1 x 52F SR20 Block
Brisbane Location - FREE delivery
  • 1 year later...
  • 7 months later...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
