On 10/06/2019 at 12:26 PM, sneakey pete said:
Don't think you'd be at a power level where a 76mm plazmaman would be overwhelmed, didn't have any IAT issues with mine doing 700 to the hubs last month. Might make packaging and purchase price a bit nicer
I like a bit of overkill, also the car will be abused at the track. So I suspect IATs will climb pretty quickly.
Where air density matters, cooler is better.
Keeping the GTX flame alive, nearly 1.3bar in 3rd @ 4000rpm on 98RON and pretty low timing. She's a bit rich, but we'll get there. Haven't quite got the IAT compensation table right :)
Also found out there's a Quick Spool function with Halalkebab Elite, I like it.
  • Like 2
Nice, that is decent!
Legotech doesn't have charge temp estimation?
Curious to know what "quick spool" means in this instance, what kind of strategy are they using?
I don't believe it does, nor have I had such experience. I generally just trim fuel based on IAT but that could be an ancient way of doing things.
Quick Spool feature, pretty much just sets the DC on 100% before you reach within say 50kPA of your targetted boost threshold before it accesses the base DC table followed by enabling closed loop boost control.
It's a bit hard to get it to not spike, just need a bit more time on the street and dyno.
Ahh ok, pretty standard - just never seen it called "quick spool" before.  Definitely a handy strategy for bringing it up near target quickly, slightly early "cracking" of the gate definitely has a tangible affect on spool.
hahah well Kebabtech literally calls it just that LOL
To be fair it pretty much does what it says, so can't exactly knock it :)   I was just amused as I was wondering what witchcraft they may have devised and it turned out to be a standard kind of thing that the setting usually has a much more mundane sounding name haha.
So how long before you put it on a dyno and send it? It's definitely looking like a potent combo, and not sure if you've seen the kind of numbers people are getting out of these turbos - but it could surprise some people
Not too sure, been so busy as I've started a new job, finished renos at home, trying to spin up a new e-comm, etc. Car is definitely right down there on the priorities list.
I would like a new 100mm Plaz cooler first before I send it's mum and yeah been following Benchmark and having chats here and there with Ben and he's getting 400~440kW on these turbos (depending on rear housing). He did say he prefers the larger rear housings than the 0.83 divided ones.
  • 10 months later...
Thread revival :)
So finally was bothered to get my car on the dyno today, and results are pretty promising.
407kW with close to 2bar of boost, still having some small boost issues. 4 port solenoids are actually much harder to tune than expected. Needed to drop the solenoid frequency down to 16hz. Using the recommended 30hz was horrific, the car would overshoot into the moon. Initially the gate had a 1bar spring, however running a 0.5bar spring helped dramatically.
Shout out to Alex and the team at Birrong Automotive for letting me do r&d on my own shitbox. They do some wicked builds there and the worksmanship is amazing. If you need a serious built car, bring it there!
Will be back for round 2 when my Plazmaman cooler arrives, will try up the solenoid operating frequency too.
Forgot to set up the derived RPM so no RPM reading nor derived torque.
Logs off Kebabtech:
Dyno sheet:
  • Like 2
Looking a bit deeper into the data, the GM open body IAT sensor, still doesn't read fast enough. After I backed off, you can see the real IAT temperatures.
It peaked at 57 degrees C (for you flat earth Americans that's 135 degrees F), chilling down the charge temp will definitely net that extra power quite easily.
Also @Lithium you might be interested :)
Base Ignition table
Compensation table (yes it looks a but ugly, but will linearise it later)
Well, it's as fast as you're gunna get, isn't it? It is always going to lag the real temperature if that happens to be changing as boost increases, intercooler heats up and rpm is changing by several hundred per second. As long as +/-10°C isn't going to kill anything, you should be OK.
And....another significant factor. The intercooler stores heat. When you load it up under a boost run then back off, the heat in the cooler transfers into the air coming through. You have a lot less air coming through when you back off, so it is reasonable to expect the core to drop a bit more heat into each unit of air and thus raise the temp of that air up very close to the core's temp, for those first second or so after you come off the hammer.
  • Like 1
That's also very true, good way of explaining it - thanks for that!
However, I am confident there's a bit more in with a better FMIC. I've already ordered a Plazmaman Pro core 2x weeks ago, but there's a big backlog (was hoping to get it before the dyno day but nope  :( )
Oh, I'm not arguing against putting a bigger core in it, or otherwise improving the cooling power. Go for your life on that. Just pointing out that I don't think a half second of continuing temperature rise after you back off is all the fault of the "slow" IAT sensor.
  • Like 1
Base Ignition table
Nice, missed the tag initially sorry!     Hope you can iron out the boost control, holding it higher up high could deliver some solid numbers - not that it's shabby now :)
So with Haltech, is that correction table basically added to the base table?  So 7000rpm and 250kpaA it's running around 26deg timing on eth?
  • Like 1
I believe from the data, the boost behaviour is due to the increase in IATs. I do have an IAT correction table which adds an extra 1% every 10 degrees the IAT climbs (probably not enough).
And yes, that's how the Kebabtech works. You have a base ignition table and you add a correction/compensation based on ethanol. What you see in that table is when E85 = 100%. There's another table where you can adjust the blend too.
If you look at my dashboard view, second column 2nd row that's the actual timing, and 2nd column 3rd row is the base timing.
I'm confident I'll get it to that unicorn 600hp mark for internet bragging rights ?
  • Like 1
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
