I own an R31 SIII Silhouette with,
93 R33 RB25DET conversion
Turbosmart Boost controller (10psi)
MARCHE systems piggyback ECU chip
BLAH BLAH BLAH!!!!
all just a matter of time and money!
Mick, I can lend you my balaclava and shotgun if you want
j/k
:headbang:
  • 1 month later...
I have a 'wanna be' skyline, lol.... VL Commodore. Its a bit of a sh1tbox atm, its N/A RB30, and the paint has almost faded to bare metal in some parts.... But soon i am going to drop an RB25DET in, hopefully a neo if i can get one for the right price. After that i'll change the exterior fully to Calais then go for a spray.
Currently though
1987 VL Berlina
N/A RB30E
3 spd auto
lowered by pedders (meh, lol)
VZ SV8 Commodore 17" wheels
Extractors, hot-dog, 2.5 redback exhaust, redback muffler, 2.5" chrome tip
Alpine head-deck, four 6" alpine speakers, alpine mrp-350 amp, two 12" subs in dual box bolted into the car.
Alarm/immobiliser/keyless entry
wood grain steering wheel
new radiator and crank angle sensor (about 2 months old)
i drive around a lot, so you might have seen me (pushin it to its limits, which isnt too much mind you, lol)
i'll try and get some pictures soon....
Hi MiK,
I had the same trouble mate. I e-mailed my pics and the guys cut em down to size using a software package and sent em back. Worked a treat.
Anyone able to help Mick by volunteering?
R
hi guy's. Im trying to put a pic of my car up but when I try to attach, it comes back with file to large or some crap. How do I attach a photo if I have just saved it to a normal folder on my computer?
  • 3 weeks later...
Hi guys, kinda new in town, well, this is actually my second year here, but i've now moved from bikes to what my mum 'thought' is a much 'safer way to travel'.... until i told her i got a skyline :P
R32 GTS-T, pretty much stock... got 17s from Japan and shes lowered a bit at the front, and I've just invested in the start of my focal sound system.
thought i'd just put this here to say hi, get into the loop
hi from ireland all .have not had car for long so not much done yet so here it goes 92 r32 gtst
hks turbo timer
apexi pigyback.ecu
hks air filter
hks sqv
blitz decat
blitz nur-spec exasust (cat back)
coming soon
hks frount mount
new turb (any sugestions)
new set of 18" volks
set of tein coilovers
strut braces
and some more eletronics
it was up on the rollers yesterday result was 260bhp iam aiming for 300+ with some internil work so wish me luck
I heard stories of the GTS being attacked with a hybrid stencil and paint can :D
:headspin: Yeah, its amazing what spur of the moment ideas lead to, my mate was doing the fmic install and we just grabbed the can and attacked the undercoat panel (one of them anyway)
:matrix:
nice car col, many 'lines in Ireland?
was that 260hp a flywheel figure or rear wheel?
sorry for the late reply supafly havent been on line .liners are still rare here which means parts are hard to get but a mate who imports cars has 2 cars for parts so i should be ok.its 260hp at the fly but thats still not bad .a mate has a r33 gts t runing 450hp at the wheels but he is aiming for 500hp. he owns the top tuning company in ireland (xtrem-autos)so he has the money and eqeipment to do it.i often ask him why he didnt just get a gtr but he said that would too easy.and it wouldnt be to much of a challeng. lol
what is ur car running mate???????? :matrix:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
