I own an R31 SIII Silhouette with,
93 R33 RB25DET conversion
Turbosmart Boost controller (10psi)
MARCHE systems piggyback ECU chip
BLAH BLAH BLAH!!!!
all just a matter of time and money!
Mick, I can lend you my balaclava and shotgun if you want
j/k
:headbang:
  • 1 month later...
I have a 'wanna be' skyline, lol.... VL Commodore. Its a bit of a sh1tbox atm, its N/A RB30, and the paint has almost faded to bare metal in some parts.... But soon i am going to drop an RB25DET in, hopefully a neo if i can get one for the right price. After that i'll change the exterior fully to Calais then go for a spray.
Currently though
1987 VL Berlina
N/A RB30E
3 spd auto
lowered by pedders (meh, lol)
VZ SV8 Commodore 17" wheels
Extractors, hot-dog, 2.5 redback exhaust, redback muffler, 2.5" chrome tip
Alpine head-deck, four 6" alpine speakers, alpine mrp-350 amp, two 12" subs in dual box bolted into the car.
Alarm/immobiliser/keyless entry
wood grain steering wheel
new radiator and crank angle sensor (about 2 months old)
i drive around a lot, so you might have seen me (pushin it to its limits, which isnt too much mind you, lol)
i'll try and get some pictures soon....
Hi MiK,
I had the same trouble mate. I e-mailed my pics and the guys cut em down to size using a software package and sent em back. Worked a treat.
Anyone able to help Mick by volunteering?
R
hi guy's. Im trying to put a pic of my car up but when I try to attach, it comes back with file to large or some crap. How do I attach a photo if I have just saved it to a normal folder on my computer?
  • 3 weeks later...
Hi guys, kinda new in town, well, this is actually my second year here, but i've now moved from bikes to what my mum 'thought' is a much 'safer way to travel'.... until i told her i got a skyline :P
R32 GTS-T, pretty much stock... got 17s from Japan and shes lowered a bit at the front, and I've just invested in the start of my focal sound system.
thought i'd just put this here to say hi, get into the loop
hi from ireland all .have not had car for long so not much done yet so here it goes 92 r32 gtst
hks turbo timer
apexi pigyback.ecu
hks air filter
hks sqv
blitz decat
blitz nur-spec exasust (cat back)
coming soon
hks frount mount
new turb (any sugestions)
new set of 18" volks
set of tein coilovers
strut braces
and some more eletronics
it was up on the rollers yesterday result was 260bhp iam aiming for 300+ with some internil work so wish me luck
I heard stories of the GTS being attacked with a hybrid stencil and paint can :D
:headspin: Yeah, its amazing what spur of the moment ideas lead to, my mate was doing the fmic install and we just grabbed the can and attacked the undercoat panel (one of them anyway)
:matrix:
nice car col, many 'lines in Ireland?
was that 260hp a flywheel figure or rear wheel?
sorry for the late reply supafly havent been on line .liners are still rare here which means parts are hard to get but a mate who imports cars has 2 cars for parts so i should be ok.its 260hp at the fly but thats still not bad .a mate has a r33 gts t runing 450hp at the wheels but he is aiming for 500hp. he owns the top tuning company in ireland (xtrem-autos)so he has the money and eqeipment to do it.i often ask him why he didnt just get a gtr but he said that would too easy.and it wouldnt be to much of a challeng. lol
what is ur car running mate???????? :matrix:
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
