Beau, don't go getting PC mate, I new what you meant, and we STILL haven't got a pic of that bloody airfreshner yet. Someone is squibbing............................keeping their mods to themselves.
Now I was thinking of using a pine tree one off the rear view mirror, but I reckon it'd interfer with my fluffy dice, so I thought I'd get one of those ones that squirts stuff every 10 minutes and put it on the dash wiff some tek screws and silastic, but I've gotta remove me crucifix and the virgin mary statue first. So you see I'm at a loss, I just don't know what to do, if only I had some pics of somebody elses airfreshner mod and then it would give me some ideas. Maybe I could get them to do a DIY guide, I don't know, jeez I'm totally lost here.....................I got this stinking bloody stupid airfreshner and I've got no idea on how to set it up. If I don't get some sort of help soon I'll have to put it up for sale in the SAU For Sale section.
Strange beasts these GTR's..
It all reminds me of Christopher Columbus, he set out to find a way to India by travelling across the Pacific and instead ended up in South America.....mind you, he didn't have a NISSAN SKYLINE MANUAL------lol
Here is my skyline (named Skye). Bought with ugly 17s and a 400R frontbar (gone now, *phew*) and stock engine but this is it now.
ENGINE MODS:
* APEXI POD
* JustJap FMIC
* Xforce 3" Turbo back exhaust with high flow cat going into a twin 2.5" muffler
* NGK Iridiums
* Splitfire coils
* HKS fuel cut defender
* Bosch 023 internal fuel pump
* Bleed value set to 9 psi atm
* GFB Mach 1 BOV
car is curretly running 174rwkw which isn't bad for the boost however it does pull just under 500Nm of torque at the wheels and we all know its torque that gets you over the line first :D
COSMETIC MODS:
* GTR rear wing
* GTR frontbar
* 400R sides
* GTR rear pods
* Jetspeed eyelids
* Factory burgandy colour
* 19" rims
* JustJap Bucket seats
* SONY Xplode System (staff prices as i work for SONY)
PHOTOS:
When i got her -
Now (also pics of my old swift) -
Edited by NicsR33
looks good now :) i must say i hate those old wheels with a vengance 3 SPOKE WHEELS DO NOT LOOK GOOD !!! (triddentts only just pass because they are black) amaru's ones i didnt like, he knows the log hit it because they were so ugly... anyways nice ride hehe
Ps i don't like 3 spoke wheels just in case someone did not get that fact. But hey each to there own.
thanks guys.
not sure mate, i bought it from a dealership. never thought i would but i stopped by to see if they had anything reasonable. along side all the holden and fords was this beaut. they wanted to get rid of it cause it wasn't wat they normally sell but they took it under their wing cause of the condition and thought it would be a good sporty family car.
the original owner lived in penrith thats all i know. i think his name was peter or something.
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
