  • 3 weeks later...
  • 2 months later...
Very nice! If the supra is anything to go by I’m looking forward to seeing how the gtr turns out :thumbsup:
If he does what he did to the supra to a gtr it will make mine look like a POS... More than it already is.
I'm trying to exercise some level of self control with the gtr - for now. It's a daily atm while I sort out what's on the list. Unfortunately it is growing rapidly.
Yeah the list will just get longer
  • 5 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
