I've recently swapped out a GT2860RS for a GTX2860R Gen2 and had the engine retuned. There's a tiny bit of lag when changing quickly from 3rd to 4th, 4th to 5th. This never happened with the GT. Could it be that the billet wheel has less inertia and therefore slows down more between gears? The other changes made aside from the turbo is a larger 32mm plumb back BOV relocated to the  throttle body side of intercooler (old BOV was 25mm and on the turbo side) and the pipe between turbo and intercooler stepped up from 2" to 2.5" . I've noticed if the BOV is set too soft the lag was worse. I have set it fairly hard but the lag persists.  Just wanting some advice so I'm not wasting time changing things that don't need to be changed eg: changing the 2.5" IC pipe to 2". I get the feeling this is just a characteristic of the GTX turbo?? Thanks in advance
  • Like 1
https://www.sau.com.au/forums/topic/476123-lag-between-gears-after-gtx-upgrade/
How much pressure does the BOV hold, if your dumping all your pressure you might want to adjust your BOV till it just starts to flutter, a bit.
I believe doing this fixed, a bit, the same issue I had with my STI.
I Basically tightened the thing down till it made the pigeon love call, a bit....
There was no real science behind this, I just wanted the BOV to not dump all the air, how much pressure was retained, f**k knows.
Someone smarter will most likely call me a idiot, won't be the first time.....
  • Like 1
They are correct about the amount of air that has to be compressed, even though it flows more it won't have as much response due to the time it takes to spool enough boost.
Also the larger bov will allow quicker and more air to be released meaning even more to fill. That's why adjusting it will help a bit.
On the bright side your car should make more power up higher in rpm with 2.5" over 2".
Also worth a mention is that the plumb back needs to be between the afm and turbo as it has usually accounted for the air blown off.
I angled mine to shoot at the turbo fins to help keep inertia.
If it's to close to the afm or it blows back through it ...isn't great.
  • Thanks 1
Wow a lot of replies thanks. There's no AFM and plumb back is angled on the intake so that's all good. I actually just had the car at the drags Wed night and have gain 3 tenths of a second with this new set up so I'm pretty happy with where it's at. BOV is set hard so it doesn't dump all the charge and the 2.5" pipe doesn't seem to affect things too badly now that I've had a good chance to test it. I'm sure though that a 2" pipe would improve the symptom.  Cheers
  • Like 1
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
