Hi all,
I'm a new member here and a new owner of a 2003 350GT Coupe (Absolutely love it).
I wanted to upgrade the seemingly outdated Bose system to a double din system.
I've read over multiple threads and don't really understand what parts I need (Shroud etc) as I see many different shrouds and am unsure as to which one will fit my car.
Would this one fit and match the colour of the silver 2003 350GT? https://conceptzperformance.com/nissan-jdm-double-din-conversion-kit-titanium-silver-infiniti-g35-03-04-sedan-coupe-v35-27500-am5kt_p_3413.php#description
Is someone able to list other parts that I would need to complete the upgrade with possible links by any chance?
My Father has a friend living in Japan who imports cars to Australia, so I could always get him to source something for me as long as I gave him the part I needed which is where I need your help.
Thanks heaps.
Jacob.
https://www.sau.com.au/forums/topic/476222-2003-350gt-double-din-install/
  • 3 weeks later...
After more research, i've figured out that this is the part I will need.
Can anyone recommend any places to do the install in Sydney? I am no where near capable enough to install this myself and want someone who has experience in installing these.
I have the Bose system, Is there anything else I'll need other than what I list below?:
OEM Double din kit
Car Media player
PAC ROEM-NIS2
Cheers.
Just do a ring around to the Audio/Auto electricians.
The V35 has been around for a long time now and it's really common to install the double din and upgrade the audio. So i bet you'll find businesses with experience.
Thanks Paul,
I've rang around a lot places in my area and a lot of them don't have experience doing them, but are happy to give it a shot. I've read places like Strathfield audio and autobarn don't do the best jobs, but i've found a few places on gumtree who are willing to do it for a good price and who's work looks satisfactory. Hopefully someone can recommend a place in Sydney that they know has the experience with it.
So I had it installed today by the guys at Lifestyle Store in Parramatta. I am extremely happy with how it turned out and how much better it sounds. They were able to make it flush with the JDM facia and were able to route the USB conveniently into the centre console. Avi looked after me really well and actually has the exact same car so was very familiar with my concerns and was able to work well with what was needed. Was stoked they were able to keep the OEM nav pop up too.
Images below:
  • Like 2
On 4/24/2019 at 2:55 PM, nickcorr said:
Looks great!! So did you order the US shroud kit as well as the line out converter?
Thanks!
Yeah ordered both from the US which was the longest process as it took a little longer than I anticipated, but it turned out looking so much nicer than the metra kit conversions. I'm more than happy with how I went about it.
  • Like 1
  • 1 month later...
On 4/29/2019 at 10:57 AM, jsmit94 said:
Thanks!
Hi mate.
I am at the point where you wre at the start of the thread, driving me a bit crazy!!
Can you help by telling me where did you get the double Din facia including dual zone climate control? Also, where did you get the English version TV/GPS?
1 hour ago, Dancoop said:
Hi mate.
Don't go crazy - just ring the guys at Lifestyle Store.
Haha. very interesting.
How are their pricing though?
I have my eye on the shroud alone rather than get the one with the a/c controls (doesn't seem necessary)  --  https://conceptzperformance.com/nissan-infiniti-nissan-jdm-68260-al710-double-din-radio-bezel-black-infiniti-g35-03-04-v35_p_3370.php
Edited by Dancoop
  • 1 month later...
On 11/06/2019 at 9:03 PM, Dancoop said:
Just found the shroud cheaper here
https://www.amayama.com/en/part/nissan/68260al710
apologies for the delayed response.
I don't know if you have had this sorted but I believe you will need both the shroud AND the a/c controls when putting in a double din. The one i ordered from concept z performance was not dual zone climate control, but they were able to take the button off the old a/c controls and solder it onto the new one that came with the fascia.
Also, my OEM nav/TV is still in japanese and not english :)
  • 1 month later...
On 29/07/2019 at 11:46 AM, gt350nissan said:
Hey jsmit94 how much did this all cost and can I just go to lifestyle and they supply the parts or do I have to buy them before I go there thanks
Hi there,
It cost me roughly $1200-$1400 for all the parts and the install.
They definitely do have a range of stereo's etc, but for the facia kit, you either need to buy a cheap metra one (they may be able to order it for you) or order the OEM one like I did from the US.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
