Nissan has add 24 more pieces to the Heritage program.
Linky Here
Nismo link in Japanese. This works better on my phone where it will translate.
The highlights in my mind are new blocks, heads and R32 body panels.
I wonder if they would be making any changes to the metallurgy.
  • Like 3
https://www.sau.com.au/forums/topic/476475-nissan-adds-to-the-heritage-program/
My expectation is that aluminium front end panels would be in high demand.  Any GTR that has suffered a front end collision has trashed the bonnet and or guards.  These are usually scrounged off another car, not repaired.  Must be in dwindling supply nowadays.
I would think there'd be a big interest in seats and door trims.  Anyone buying the bits that are already available for a restoration project would almost certainly jump on the most visible parts.  Door glass (to get rid of scratches) would be a possibility, along with the various electrical components in the doors (window switches, power window boxes).
Some of these things may still be around in some numbers in NOS, but I'd expect a lot to be running out.
Unfortunately I don't see the front panels listed. Only the bumpers and rear quarters. I hope the fronts will be added.
I haven't needed to look up windows.
Are they that hard to get?
Didn't think the 05U blocks ever went out of production. Still always been obtainable. New 05U casting type maybe ?
We need to find some more info on this.
I didn't say "the" front panel.  I just said that front panels should be in demand, in response to previous poster's "see what they produce next".
As to block metallurgy......I would not hold my breath.  It's not as if the cast material they were using had any problems.  The design, on the other hand, is where the block is weak, and the design is what they really won't change.
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
