Hi,
For the guys that are running single turbos on their cars(whether R's or Non), how do you protect the wiring harness on the passengers side by the turbo?
I have a 9180 which a 4 inch dump, which I will get ceramic coated(exhaust/housing/dump) going in soon. I will be sticking the gold reflective tape on my exhaust side plus on the firewall anyway, but the poor wiring will get burnt to a crisp in no time... Also, will boil the brake fluid with the ABS controller inches away(That's another problem).
All I can see are 2 options:
a) Re-route the loom under the fender(Can you already by extended looms? Wiringspecialties dont sell one)
b) Heat shielding(Reflective tapes + metal surrounds and heat sleeves all around the harness.
Thanks.
Re routed over the strut tower after melting it the first time...
Also for longer term keeping heat out of the tower/ABS area, good quality wrap on the dump and also a good turbo beanie. That made a huge difference to secondary underbonnet temps i found.
Those fireproof sleeves are pretty bloody good.  If you can get any other more primary heat shield in there (even just the coating) it should be survivable.  If you want to exercise paranoia, you could slip a thermocouple in there with the loom at the likely hottest spot and see what it gets up to.  If you're comfortable, then leave it like that.  If not comfortable, then you plan to reroute the loom.
Tidiest and most reliable solution is to re-route outside the engine bay.  Get it right away from the heat source.
It's one of those mysteries why the factory routed outside on the right hand, and kept it inside on the left hand side.
Unplug the harness from the big 2 connectors near washer bottle and feed it inside your guard
yes it fits as I have done mine and my mates cars far more cleaner, uncluttered and protects it from the heat
  • Like 1
Which connectors sorry? Please indicate as per pics on this link(Found some reference pics on GTRUK) - https://www.gtr.co.uk/forum/175254-engine-bay-wiring-loom-run.html
Thank you!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
