10 hours ago, KiwiRS4T said:
Method attached. I haven't done it myself just saved it from another member in case I should need it one day.
Thank you. 'File appears to be corrupted'  ??
Is there a pdf version? Sorry to be a pain
Setting the final clutch pack clearance after plate modification is key and requires doing the plate mod in two steps. Too tight (under 0.2mm) and transfer will drag plates constantly and burn out. Too loose and obviously doesn't fully lock. Proper way to get clearance is to change the front retaining plate thickness (they come in 0.2mm increments from about 4.6 - 7.0mm), so it's not actually "shimming" like adding or removing extra shims to change a clearance.
My old man does them all the time and have noticed a few particular specific things you have to watch out for when doing them, as you can stuff it up fairly easily if you don't know what you're doing. Off the top of my head you need to:
-Setup with the plate clutch pack clearance MUST be done the with Attesa actuator installed. If not the clearance will end up too tight and basically lock transfer up permanently.
-final plate arrangement count can't change ie. has to always start with 5.0mm retaining pressure plate at rear and change clearance with front retaining plate at circlip AND
- excluding the 2 retaining plates has to always end up at combined metal and friction plate count of 19 (from standard 7 friction 12 metal arrangement to 10 friction 9 metal or anywhere in between that)
-plate at each end of the 19 MUST be a friction disc, that contacts each retaining plate
-metal plates have to be carefully reassembled to make sure they don't block oil feed holes into drum (which they can)
-presoak friction discs in ATF before reassembly to embed fluid into material. Can rip off friction disc plate material on new unused plates if not done.
-checking transfer oil pump sealing
  • Like 3
  • 3 years later...
Thanks to the great information above, i have got stuck into my own transfer case upgrade.
I am using an R32 case.
Using the R32 5mm rear plate, i notice the first friction plate will not reach the internal splines.  If i run the plate anyway as a spacer and then chuck in a steel and another friction, the 2nd friction is just off the end of the splines.
Has anybody had any issues with this? I worry that when the 4wd is engaged it will not line up with the splines and will strip the teeth off the friction.
Backing plate installed
1st friction
Any ideas?
Thanks
Dont do anything that your talking about regarding spacing - you've just f**ked up
So to elaborate you can't assemble the clutchpack drum outside of the transfer case, that's your problem. It's needs to be fully assembled including on the actuation side before you install any plates as stated above.
Yes i aware of that. I had pulled it out of the case to try and see why the bottom friction was not engaging on the drum. You can see in the photos that its miles off. I was asking to see if anybody had the same issue as it was the same on the 32 and 33 drum i had.
I pulled it completely apart and found the clips that hold the thrust had fallen out and were stopping the inner hub from going all the way to the bottom of the basket. There was no mention of this in the manual that i could find.
I reassembled it and put a cable tie at the other end to keep the inner hub hard against the half washer clips until the front cover is installed. If it is pulled forward, the outer ring call fall off the half washers and stop the hub going all the way in
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
