Had a little fun on the weekend, thought it might be a learning moment for some others.
Recently there have been odd squeally noises when my car was on boost. Not all the time, usually while not fully hot under the bonnet. Intermittent nature of it made me wonder if it could be a gasket leak on the hot side (sounded like it was on the LHS of vehicle).
Sort of gradually became a little more frequent. So I chucked the inspection camera in under the turbo heat shield and found, to my mild horror, that the rear lower turbo nut had dropped off at some point. The lock tab for it was still bent up sufficiently that you'd think it impossible for it to happen. But happen it did.
What was somewhat more frightening was that peaking the camera on the other side showed that BOTH the other two nuts on the front side were loose. Several threads out. Both still in contact with their locking tabs. WTF! Only the top rear nut was tight.
So there you have it. Turbo was barely held on to the manifold and I could barely tell the difference in the car's performance. Sure, it was no doubt a creeping death onset and I didn't notice the slow decline in its spooling response, but it was still pretty much as fast as it ever was. After doing up the one nut that I could actually get a tool onto (so obviously, I have some more work to do!) it doesn't shriek any more and it seems to come on boost a little more aggressively. But there you go. It is surprising how little effect having the turbo almost to the point of falling off can have.
  • Like 1
I guess the rate of leakage from the flange was still less than what would have been wastegated, so the wastegate would have stayed closed for longer to compensate?
Or perhaps you just drive so slow already that the impact was negligible? :P
See post from September last year in the EFR thread about my encounter with this issue...
It is worth noting that I did do a PB at QR with the issue also. turbo was to the point where you could move it a few mm at that point. drove home too with no issues
Yes, absolutely. At least when it is actively controlling boost. I think if the gap is wide enough to leak noticeably during spool, that it will kill spool (compared to having the WG held closed by the controller, like it is supposed to be). And after tightening it back up and having it feel a little better coming on boost, it was probably leaking enough.
Most of the time yes. I don't have anywhere near as much power as many on here have, but even that is enough to cost a great deal in tyres and -ve attention from the guys who drive the unmarked cop cars.
Edited by GTSBoy
  • Like 1
I've found those OEM locking tabs to be useless, even when hammered with an extension so it forms around the nut....so i don't bother with them anymore.
Only thing that has stayed in place for me was using inconel studs and copper locktab nuts....stayed on damn tight, so far.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
