Hey all,
ive got a rb25det with full intercooler piping with blitz fmic, intake piping, turbo back 3 inch exhaust and a tune with power fc and I’m running about 12psi on stock op6 turbo. I was wondering if I get a aftermarket exhaust/turbo manifold would it increase performance?Because it’s the only stock piece I have from my whole piping system. I’m not 100% on the power of my car but it should be at least 200rwkw and I’m not planning on building it up to anything 400+ anytime soon. Would the car require a retune if I get one?what products do you recommend?
thanks
Not really. A big aftermarket manifold might improve your top end power a little bit compared to the stocker. But only a little bit. So little that you'd be hard pressed to tell the difference. I mean, we're talking the difference between 195 and 200 rwkW. There might be a small improvement in spool response. Or there might be a decrease in spool response. Depends a lot on the specifics of the manifold that you put on. One with big runners designed to support heaps of flow/power will likely suffer in spool. One that is carefully designed to get the gases to the turbo efficiently might improve your spool, but won't support as much flow and power and is therefore unlikely to be something that many manufacturers would have on their list of existing offerings. No-one's really going to spend up to $2k on a manifold to optimise the response of a stock sized turbo.
And your car is unlikely to be "at least 200rwkW" right now. It will be lucky to make a real 200rwkW at that boost on the stock turbo. Mine makes a trustworthy 190rwkW with the same mods (different ECU, but still, tuned). I could possibly give up some safety in the tune to get it up to 200, but they're really not going to go a lot higher than that. Optimistic dynos not being part of my consideration, of course.
Just hi flow your turbo if you want more power on the cheap.  Its a bolt off/bolt on mod so only costs for the turbo work and a tune.  It is possible to get anywhere from 220 to 260rwkw depending on your supporting mods.
Or if you have $$$ buy a new turbo, maybe a Hypergear one, talk to Stao?
Yeah, but to avoid wasting half the potential improvement, the budget really needs to include an AFM and injectors, likely a fuel pump, conceivably a clutch. But what's another grand or two?
I otherwise completely agree.
Still a new turbo, regardless if it's being used to it's potential will still be yield more performance than a manifold (which might improve nothing besides sound).
And if you're living life on the edge, just max out your AFM and add a FPR to bump up your fuel rail pressure to get a bit of headroom from your injectors. Should be able to yield a healthy 220~230kW with the AFM voltage flat lining lol.
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
