Is closed loop ....o2 feed and active changes?
And open loop means the loop is broken and or uses maps. Loaded maps being wot and high throttle maps tuned in the ecu like an idle map but for when the cars power is under load?
Google closed loop and open loop control systems.
Get on YouTube if you still can't work out what an open/closed loop control system is.
It is very clear you do not understand what each term means.
Regarding your 'load map', there are high load areas on the fuel and timing maps, I've never seen a separate map specifically for when the engine is on high load. I hope such a thing doesn't exist because it would be a pain to tune, constantly swapping between multiple maps.
While your googling, Google fuel map and have a look on the images, you'll see the maps cover the entire rpm and load range the engine operates in.
I was serious about the English as a second language question, do you speak another language?
  • Like 1
3 hours ago, Slap said:
Wide band gauge is delayed too much to save a bad leanout that is why it should be monitored by the ecu or other different automatic safegaurds.
So how would the ECU monitor the air to fuel ratio?
"Defining Open Loop and Closed Loop o2
Open loop is when the ECU is not referring to the o2 sensor for feedback. ... Closed loop is when the ECU does refer to the o2 sensor for feedback. Using the o2 sensor the ECU will modify its fuel table based on the readings the o2 sensor is seeing."
Slap has invented the world's first mechanical air fuel ratio gauge. Think of the cost savings, never having to replace another sensor again
  • Haha 1
  • Confused 1
I may have invented load maps but ment load area of the map. Eg....
"Pulling a fifth-wheel camper up the Rocky Mountains at highway speed, for example, puts the engine under a huge load and requires a lot of energy. The ECU gets input from all of the sensors on vehicle speed, air intake, pressure, and temperature and plots a specific point on the imaginary graph. The computer is programmed to tell the fuel injectors what to do at that very point on the fuel map, and it sends out the appropriate message -- without any more input from the driver."
open loop and closed loop is well known i believe and maybe you should do some googling and maybe you will see where my terminology isnt correct. But its the jist.
That's not actually true. Was clearly written by someone with half an understanding. What really happens is that the ECU leaves the values in the fuel table alone and DOES NOT modify them. It may or may not use them as the base for the calculated fuel qty that it will then apply the feedback factor from the O2 reading, and also apply the long and short term fuel trims if and as they exist.
And how do I know? Well, the Functional Description documents that I have been writing recently for Burner Management Systems for a couple of different rotary kiln systems with fuel-air ratio control WORK IN EXACTLY THE SAME WAY. I even have a CO sensor in the kiln exhaust as a Safety Function.
The capitalised names above are capitalised for a reason. A Safety Function is such a serious thing that we use capitals when writing about it. A Functional Description is what is used by the system integrator and programmer to write the PLC code. All of this is covered by AS 3814 and AS/IEC 61511.
The words that are in all caps are just me shouting.
Is that not what it is saying in laymans terms, "as it MODIFIES" does not represent any one actual change, and is interpreted to myself as basic word usage so that it can be used to cover all different aspects and types of change and ecu's.
It doesn't modify shit, it applies a compensation/trim in either short term and/or long term trim.
The fuel table stays as is. However in aftermarket ECUs it stores the trims and you're able to apply it to the base table. This is the only time it "modifies" the fuel table.
  • Like 1
  • Haha 1
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
