Hey All!
Wondering if anyone can help me, had some rain here recently and noticed water got into the cabin. I'm pretty sure it happened while it was parked and not driving. It's only in the driver side footwell and I've checked the fire wall and there is no obvious place for water to enter (such as a grommet or such.
Have pulled the carpet back and it looks like it's leaking from the centre console maybe? Just wondering if anyone has had a similar issue or has any thoughts on where this could be from?
The water patch seems to be from the left of the clutch pedal against the gearbox tunnel (can see the discolouration on the photo.
Any help would be sooo good :) (is in a R34 GTT)
Edited by Tobz
https://www.sau.com.au/forums/topic/478751-water-leak-to-cabin-any-ideas/
7 minutes ago, GTSBoy said:
  • Windscreen seal.
  • Plenum chamber drains blocked.
Makes sense. I'll try and see if either of those are the issue.... Is there an easy way to check either? I had a look at the windscreen but it's hard to tell if the seal is 100%
I'll have a bit of a google
@GTSBoy
Ok pulled the car apart, finally have located the rough place of the water entry
The water seems to be dropping from above the throttle pedal. I'm thinking it's the windscreen?
Also cleaned up what I think are the plenums? They had leafs but nothing major. Picture also attached
Edited by Tobz
1 hour ago, GTSBoy said:
There's so much visible rust there that the windscreen lip is bound to have rusted.
It was all just black grime there, took me 20 mins to clean it back to this. Will probably sand it back and paint it up later this week
If it is leaking at the firewall near the accelerator then you have to take the front wheel off, then remove the plastic guard liner [screws and clips].  Behind this there are a few grommets and such for gauges and cables etc.  You won't see these grommets in the engine bay.  I'll bet that one of the grommets has been split for aftermarket gauges or boost controller.  Silastic out of a caulking gun works.....well did for me....but that was almost 20 years ago.
  • Like 2
Cheers! I'll try that first before the windscreen! Worth trying the cheaper options first!
  • 4 weeks later...
Ive had this problem as well but only happens when driving in the rain
  • 2 months later...
It was 100% this. Took me a while to get to it, but pulled it apart and found that the guys who did the alarm used the grommet there and just used masking tape to cover it. Tape loosened and formed a funnel which flowed the water into the cabin. Used some loctite putty thing and sealed it up good!
  • Like 1
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
