Obviously an expensive ecu is the best option by far but the power fc still gets the job done and has a place.
I been running a power fc with my RB3025 at 350kw for years on dedicated E85, its simple and does the job for those that want a simple solution, cost me $600 and a tune.
Most tuners know a power fc and can tune it easily, i personally like the hand controller to look at knock and check sensors although i know the accuracy maybe not perfect.
Just think cost, elite 2500 is 5 times the cost and for a simple street driven 300kw do you really need bells and whistles.
definitely valid points comparing power fc to the likes of haltech and link etc but if we try say comparing apples with apples, when it comes to price anyway I think it's pretty hard to go past a Nistune vs a Power Fc... Just my 2c anyway...
  • Like 1
You'll be silly to discount a Nistune when it has flex capabilities out of the box, not to mention the option of running a single R35 MAF instead of 2x MAFs, etc. as there's a check box to for you to select from.
Look, if you were given the PowerFC for free then sure why not.. but if you had to go buy something within budget, a PowerFC is silly.
  • 3 weeks later...
I ended up returning the (canceled the order on the FC) and found a couple places here in the US that offered the NIStune. I ordered that and should be here this week.
My question is. Without having added or done anything besides installing the board onto the ECU and plugging it back into the car. Would I still be able to drive it as normal?
Theoretically, I feel I'd be able to plug it in and still drive the car, but if not I do have the software and the consult cable to be able to see my ECU.
I dont know how to tune with the NIStune but I have been looking over the website and saw they have various PDFs with tons of info. Basically what I got from it would be just to watch knock and adjust fuel trim since I didnt change anything on my MAFs or injectors and not doing e85.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
