I Have an R34 GT N/A and I rebuilt it and converted the working engine With:
-CP Neo forged pistons
-Manley Rods
-Garret Gt3071r DDB Turbo
-Series 2 stock fuel rail and injectors
-Series 2 exhaust manifold
-SplitFire Neo coils
- New iridium NGK Plugs
-255 Walbro Fuel Pump
-Freddy Forward Facing intake
-Stock GTT R34 NEO Turbo ECU
-Many Many more....
After my conversion build with all new parts, i primed it and started on the first Crank.
CURRENT STATUS:
-Crank and starts instantly every single time and runs only when applying throttle
THE PROBLEMS
- Sounds great however it if you do not apply throttle and leave her idle, she is struggle to breathe and stutters and will die
- Jumps up and down the rev range by her self
- Cannot find a decent idle and when she does its not for long
- After reeving and she goes back down she dies
- Sometimes when reeving she break up on her own
SOLUTIONS/TROUBLE SHOOTING
- TPS sensor needed to be adjusted to get the right Ohms. After we fixed it it seemed to be more consistent when reeving and staying and holding at an RPM's and slightly better idling.
- Idle air Controller,  adjusted the screw and tried over 10 positions, although it actually really helped idling it still did not cure the dying at idle problem and finding a good idle problem.
NEXT STEP (tomorrow)
Take a look at the base/ignition timing with a timing light to the notches on the crank pulley and adjust it with the CAS sensor?
DOES ANYONE HAVE EXPERIENCE WITH IGNITION TIMING? HOW DO I DO IT PROPERLY? WHAT DO THE NOTCHES INDICATE? WHAT NOTCH DO I WANT TO BE AT?
ANY ADVICE IS GREATLY APPRECIATED
There is a good guide on timing in this thread. BUT use the no 1 spark lead not the loop at the back of the engine.
You will need a Nistune chip in your ecu, a better AFM and probably better injectors.
I take it you have properly cleaned your idle valve and have your BOV plumbed back and not venting to atmosphere.
  • Like 1
UPDATE: for anyone who may be interested and can learn from this in the future....
It was MY Idle Air controller unit and it also being not having the vacuum lines  plumbed correctly.
After this a few test drives, adjusting the idle air screw and letting the ECU learn, i am almost completely sorted
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
