They don't even make T2s in 296mm (non-Brembo) or 324mm (Brembo)... whoever that person suggested you those rotors might have no idea :)
I would (if I were you) run DBA4000 T3 all round (non slot, longer life, less cracking, less warping, good cooling compared to OEM & OEM styled rotors). Get slots if you want the looks.
Dirty plug, I can source & supply DBA rotors, Elig brake pads & Intima brake pads for you :)
2 minutes ago, Matty George said:
The car is a weekend cruiser that’s it. Sumitomo calipers on it. It’s not a track car and I don’t thrash it. Just after something that will perform the best if I give it some.
I would recommend good set of Elig Sport brake pads, DBA4000 T3 all round and some good brake fluid to go with it.
Yeh sweet thanks for the advice. If you suggest that combo I’ll jump on line and get a set all round. I do prefer the slotted look but to be honest with the original rims you can’t see to much of the rotor anyway.
Then dont waste money on slotted rotors as they only make a difference on the track and even then not much.  They do, on the other hand, do as below.  Just go buy some RDA rotors.  Cheap and they work just fine.  Worry more about the pad than the rotor.
Edited by djr81
20151004_172907.jpga
Agree with rda being great, especially for the money. Even plain rotors crack, see in your pic above, the little micro cracks. Once you have a lot of those, they start to join up and become the big gash. All rotors do it eventually, some just last longer than others. I just replaced a pair of  $1100 stoptech 2 piece rotors due to micro cracks. Didn't feel like living dangerously any longer. Id been ignoring them for a while but recently got to the point where there was just too many to ignore any longer.
I never get slots for myself, however everyone that buys off me has always wanted slots - so yeah customer is always right :)
However, I did find (might be all in my head) that DBA rotors cool better than OEM style rotors, as the internal cooling channels have more surface area through those kangaroo paws.
This is purely based on bro science, where I notice I could do 8~10 laps at Wakefield when I moved from OEM rotors to DBA4000 rotors with the same pads, and same calipers.
I put slotted (the ones with dimples also) RDAs onto my car, against advice (and also against my own opinion, but I thought I'd try them anyway). I'm not sure I'm convinced by the pedal feel. Probably wouldn't do it again.
FWIW though, I don't think that slots are guaranteed to make rotors crack more/worse. Not like drilled holes do, anyway. They might increase the chances of cracks on discs that get the shit kicked out of them, but not on a streeter.
Rear rotors ive cracked plenty of, quite frequently. Slotted,plain, dimpled they all suffered the same fate. Surprisingly the plains cracked the quickest but also had the harshest pads. Definitely heat related issues, the rears being smaller, thinner and getting less airflow. Im currently running some dim sim brand rda dimple copy rears. Yep copies of rdas, wtf.  Have done a few track days and show no signs of cracks, yet.
Maybe it's time you moved to Elig KT111 pads :)
I can help
I can help
Atm i have a box with left over 50% intima type d, pmu, winmax pads im working through. Trying to keep on budget lol but I'm always up for trying new things out so pm incoming for quote.
  • 4 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
