Hello  Everyone,
After fully forging and building my r34 2 door rb25de neo to a turbo conversion...  i would like to do a brake disc and caliper upgrade.
I know for sure for sure for sure there IS a thread  somewhere that i read a couple weeks ago but i just spent a hour looking for it and no luck.
My question is, can i buy brake discs and calipers upgrades for a r34 GTT coupe? (cant find aftermarket shit for the NA r34)
i think i heard something like the N/A brakes on the r34 is actually r33 gtst brakes and discs.
If anyone can give me some advice or even direct me to a thread it will be greatly appreciated!!
https://www.sau.com.au/forums/topic/479250-1998-r34-gt-na-coupe-brakes/
Yes. What I can't remember is if they'd given up on 4 stud wheels on the NA by the time they got to the R34. If you have 4 stud, then it is a lot more work and stuff you need to get - because the turbo stuff is obviously 5 stud.
Nope.
NA R34s were still sliding caliper junk. R33 GTST are 4 pot Sumitomo on 296mm x 30mm rotors.
There's a lot more than one thread covering this stuff on these forums. Use google to search the forums. You will get much better results.
C'mon Dylan You need to try harder mate, I searched this forum using "4 stud brake conversion" and got 10 pages of results
Mate, you are not searching hard enough or not reading the entire threads. Try this on this forum
R34 Non-turbo Rotor Size And Pads
and it will lead you to this
http://wiki.r31skylineclub.com/index.php?title=Brake_Upgrades_Miscellaneous
Read the threads in their entirety otherwise you miss stuff.
Edited by Rusty Nuts
  • Thanks 1
if you want cheap Brembos and don't want to pay the GT-R tax, get yourself 350Z Brembos calipers, Rotors :)
They will sit a bit future out compared to the GT-R ones, but if you've already got some decent wheels you'll clear it.
Oh, here's a guide I wrote many years ago:
http://www.trak-life.com/diy-350z-brembo-brakes-conversion-nissan-skyline-r33-gts-t-gts-gts-4/
  • Like 1
  • Thanks 1
I'm also not sure if the R34 NAs went to the 14mm caliper bolts like the turbos did. If they are still at 12mm, then fitting R34 turbo calipers requires changing the threaded inserts in the calipers.
If the NAs are 12mm, the you could fit R33 calipers easily enough (on the 296mm rotor) or you could fit R32 calipers (preferably using a dogbone to push them out so you can use the 324mm rotor - which you CANNOT do nicely with the R33 caliper).
The info on 12/14mm is available on here. I just can't remember.
  • Thanks 1
Habib, if you read the guide it will make sense.
No thread inserts, those are gay.
  • Haha 1
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
