Hello  Everyone,
After fully forging and building my r34 2 door rb25de neo to a turbo conversion...  i would like to do a brake disc and caliper upgrade.
I know for sure for sure for sure there IS a thread  somewhere that i read a couple weeks ago but i just spent a hour looking for it and no luck.
My question is, can i buy brake discs and calipers upgrades for a r34 GTT coupe? (cant find aftermarket shit for the NA r34)
i think i heard something like the N/A brakes on the r34 is actually r33 gtst brakes and discs.
If anyone can give me some advice or even direct me to a thread it will be greatly appreciated!!
https://www.sau.com.au/forums/topic/479250-1998-r34-gt-na-coupe-brakes/
Yes. What I can't remember is if they'd given up on 4 stud wheels on the NA by the time they got to the R34. If you have 4 stud, then it is a lot more work and stuff you need to get - because the turbo stuff is obviously 5 stud.
Nope.
NA R34s were still sliding caliper junk. R33 GTST are 4 pot Sumitomo on 296mm x 30mm rotors.
There's a lot more than one thread covering this stuff on these forums. Use google to search the forums. You will get much better results.
C'mon Dylan You need to try harder mate, I searched this forum using "4 stud brake conversion" and got 10 pages of results
Mate, you are not searching hard enough or not reading the entire threads. Try this on this forum
R34 Non-turbo Rotor Size And Pads
and it will lead you to this
http://wiki.r31skylineclub.com/index.php?title=Brake_Upgrades_Miscellaneous
Read the threads in their entirety otherwise you miss stuff.
Edited by Rusty Nuts
  • Thanks 1
if you want cheap Brembos and don't want to pay the GT-R tax, get yourself 350Z Brembos calipers, Rotors :)
They will sit a bit future out compared to the GT-R ones, but if you've already got some decent wheels you'll clear it.
Oh, here's a guide I wrote many years ago:
http://www.trak-life.com/diy-350z-brembo-brakes-conversion-nissan-skyline-r33-gts-t-gts-gts-4/
  • Like 1
  • Thanks 1
I'm also not sure if the R34 NAs went to the 14mm caliper bolts like the turbos did. If they are still at 12mm, then fitting R34 turbo calipers requires changing the threaded inserts in the calipers.
If the NAs are 12mm, the you could fit R33 calipers easily enough (on the 296mm rotor) or you could fit R32 calipers (preferably using a dogbone to push them out so you can use the 324mm rotor - which you CANNOT do nicely with the R33 caliper).
The info on 12/14mm is available on here. I just can't remember.
  • Thanks 1
Habib, if you read the guide it will make sense.
No thread inserts, those are gay.
  • Haha 1
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
