2 minutes ago, silviaz said:
Wait what? Are you sure? I heard no noise and I checked with an endoscope the pistons look the same.
You won't hear a noise and in the case of a mis-timed engine turning over the contact is not normally large enough to leave a large mark or damage, but is enough to bend valves
How do you explain the extra resistance when turning over at some points? With plugs out it is the same to spin an engine over, no Change in resistance
ah fml, so to confirm this should I get an mirror for my endoscope to check if the valves are bent?
9 minutes ago, Rusty Nuts said:
No, thats a compression tester, you will need an air compressor but a small one will work fine
https://www.supercheapauto.com.au/p/toolpro-toolpro-cylinder-leak-down-tester/392419.html
Ok ill put my engine to tdc on the silver links and do it. I assume thats the correct procedure.
Edited by silviaz
19 minutes ago, Rusty Nuts said:
you need to do all cylinders at TDC  your firing order is 1 3 4 2 so rotate one full turn after no.1 then do 3 and so on. check out some youtube vids if you haven't done one before.
I see thanks will go from there.
17 hours ago, Ben C34 said:
I would do a leak down test, or just put compressed air in and listen if it is leaking out the valves, no mirrors.
Hey man so I've set up everything and I am not touching anything anymore until a mechanic comes I'll get them to do the leakdown test since they will probably have the tool will save me some money. I also called a couple of mechanics and they said about the resistance it can happen cause pressure builds up or like you said because valve touching piston. In this vid on the first time I try to crank it, it's very tight then it's ok then it's right towards the end. This is what you're referring to right?
35 minutes ago, Ben C34 said:
If the spark plugs are out there is  no resistance to build up. It definetily seems from here you have likely bent valves. Hope not but that would be a long shot
dammit.  Maybe jobs like these in the future leave for someone more qualified. I would have thought following the manual would of been enough lol.
On 12/11/2019 at 8:32 PM, Rusty Nuts said:
You have been struggling with fix since early November, you probably need to get someone knowledgeable in front of this engine to help you.
Four days ago I suggested you get some help, but you were not having that!!!!!
I did I called a mechanic, and he said it was ok to crank the engine so I did. Just leaving the rest now for the mechanic. They are just busy as hell will be waiting a bit until I get my hands on one.
I also read back when you wrote about how I didn't have the marks lined up when I started I see what you mean now. I referred back to the manual and while it did say rotate to tdc I didn't realize the links were supposed to be there as well.
Edited by silviaz
Great news!! Got the mechanic he didn't have to take the timing cover off,  and did the compression test had 190-210 across all cylinders. Which seems quite high service manual says 156. But cranked it didn't have any usual noises. Tomorrow will be the test to see if it turns on fine.
  • Like 1
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
