G'day All
Well it's been a while since I've owned a skyline and I'm looking into a R34 GT-T, I sold my last one over 5 years ago at 120xxxkm & the one I have my eye on currently has just under 190ks. My hesitation lies in the possibility of re-selling down the track when it's more likely going to have done 220ks...do you think the R34 will retain value past 200,000km and a market for buyers at that km? I'm not massive into modding etc, would just be something to enjoy owning once again. Cheers, Neo34
3 hours ago, Ben C34 said:
As time ticks by the ks matter much less of they aren't verified.
Does the car you are looking at have full history to verify the ks? Did your previous car?
It has some import papers but nothing else, I'm strongly considering spending the $ and getting a check from Japan if it's going to assist in verifying ks
For me, it would depend on condition at these kms. 100+ kms on the clock and you know you aren't buying a low km car.
At that point you should be looking at condition more than anything else.
You could get a check, but i'm not sure if it would be worth it. If it were me, i'd rather spend the money on a decent mechanical inspection by a Skyline expert (or at least someone familiar with them).
Regarding your concern around re-sale value, at these price points, I would expect these to hold their value over the next 10 years. However, I would not expect this to appreciate. If you were super keen on buying something that will appreciate, I would suggest looking at a stock, low kms GTT or equivalent.
Condition is the only thing that matters. My car is at 230k km and has had 2 engines, 4 different transmissions, 2 rear subframes, 3 different sized front brake setups, every suspension bush changed at least twice, some as many as 10 times. 3 different radiators, 3 ECUs, etc etc etc.
Some parts of the car are still original.
Thanks for the reply and I agree with your projection; I’m specifically wanting something that will at a minimum hold value i.e a bayside blue GT-T or a Stock low km GT-T with factory options. PMd you something for further discussion
  • Like 1
1 hour ago, niZmO_Man said:
Definitely do a history check. Could have been smashed and fixed, could also be a good condition import, who knows.
Will do, it’s $95 USD...but a small investment for a 20k + car
This is true. 99.9% of Skylines now are some variant of Grandfather's Axe/Ship of Thesus. Condition and kms are nearly completely disconnected nowadays.
Nearly ?
6 hours ago, Dose Pipe Sutututu said:
Remove dash, replace with MoTec C1212. tell next buyer no idea of KM.
I'm after one that's as close to stock as possible, this would probably hurt the value but yes would stop Km going up ?
On 15/01/2020 at 9:02 AM, KiwiRS4T said:
Checkout the steering wheel, has paddle shift, may have been a conversion or replacement....
VIN is JN1GCER34A0202109 which shows as factory auto, good spotting.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
