Hi guys, long time listener, first time caller. So I've done some basic mods to my 33 and was somewhat disappointed with the results. Mods as follows:
Front mount
GCG high flow running 18psi
740cc apexi injectors
Upgraded coils (yaris)
Walbro pump
Z32 afm
Power fc
Exhaust and bellmouth dump
E-boost 2
Maybe more, can't remember............
Any who, I live in the NT. Car made 201kw on the dyno on 98ron. My question is will a set of cams help me power wise? Not chasing huge numbers, just wanna flog it up to the 130k speed limits here ;) Car is responsive, drives really nice, but everyone wants more power yeah?
Any feed back or advice on next step for upgrade/more power appreciated.
Thanks in advance.
https://www.sau.com.au/forums/topic/479906-cams/
Hi. My god very few people from the NT on here these days, I'm about the main one. Alice or Darwin ? Yes of course cams can give you more power, but at the end of the day, more power, get bigger turbo.
What dyno were you on ?
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926006
Hey mate, I'm in katherine, got one of maybe 4 skylines here haha. I was on the dyno at peckys.  It was a good 18 minths ago, just been slack with more upgrades. Had my tune done in the build up, so ambient temps were garbage. You in Darwin? I wanna stick with low mount, as factory as possible, hence the high flow. Just after a bit more kick.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926008
Alice mate. Not too many now here either, used to be heaps. Probably about 20 skylines, including 6 or 7 R32-R34 GTR in town and I own half of them. There are 3 R35s in Alice now though.
I think you need to talk to Tao from Hypergear in Melbourne for the best stock fitment turbo for your needs. Has a thread in the Forced Induction section. Will definitely get you more power from one of his recommendations.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926010
Thanks mate, I'm happy with the turbo, mainly after the low/mid range increase. From what I've read 256 poncams will drop straight in and retain vct. This is my first "performance" car and I have done all the work myself in my shed, so it's all a learning experience for me.
Holy shit, you've got yourself a collection!
I'll hit up Tao when I finally take the plunge. Thanks again!
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926011
You can't get more bottom end from bigger duration cams, it makes more power up top. Look the cams will probably be good, but don't expect them to improve your low end. For low down power it doesn't get any better than the stock ones. Higher lift with cams is good, but if you like the turbo and want more bottom, it's RB30 time. Sounds like from what you want capacity is the only thing that'll do more low end for you.
Bigger turbo, drive it harder. I miss the open speed limits.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926012
Well Labor took them away when Adam Giles and the CLP lost the election 4 years ago, he was cool. When Giles got in the limits were lifted within 3 months. The way it's looking Labor will lose the election this year in the NT because Michael Gunner is a Fckwit, CLP will get in and we'll get them back. Since I've lived here it's always been open, unless Labor is in government. Passing cops at 180 - 200km/h, then pulling away from them at 250+ was pretty cool, and they would just wave at you as long as you weren't all over the place. Not at the moment, get flashed at 140, ticket.
Also whenever it's open, all the manufacturers come back to test here. I take it you've seen when Craig Baird was driving in the Porsche 918 on youtube around Alice and Ti Tree, mad prick was doing around 350km/h ! Legally !
I am way off topic.....?
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926016
OP when i had a v.similar setup to you, i made 260ish rwkw pre-tune on 14.5 psi, using a Hypergear hiflow and Tomei 256 poncams. Largely due to turbo i believe, but both tuners i used on that setup commented about how the cams helped up top.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926039
Thanks hardsteppa. Are the poncams a straight swap for factory? Eg retain vct? I'm hoping once I move back to the east coast and get my tune redone it should puck up some more power, had a horrible time with the "98 octane" fuel up here. I think cams will be next in line for me.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926041
Yeah in Darwin has it, not Katherine though, does it ? Darwin and Katherine would be a shit place to tune. Alice is good, if there was someone here that could actually tune, and on a dyno that was accessible.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926044
Yep, got it in katherine. We also have a puma that has 98 but I don't trust it.
I had to wait for a bloke to come up from Adelaide to do my tune, I had previously had a tune done in Darwin but it was expensive and didn't give me any results.
I made the mistake of getting my tune done in the build up too :(
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926045
Fck that Puma shit. Blew my 2.8 up on it at Red centre Nat's 2018. Pulled engine down and it was so dirty and gritty on the pistons as if I was using 91. Every time pulled one down after BP ultimate, absolutely clean as. I wasn't the only one, about 10 other cars went that weekend too.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926046
Straight drop in for poncams. Retains vct. Had an adustable cam gear on the exhaust but ditched it as the poncams degree'd up to where they were meant to on zero adjustment.
You don't "need" to as such but i would do valve springs at the same time, if you're still running original still. Supertech springs and titanium retainers are good.
https://www.sau.com.au/forums/topic/479906-cams/#findComment-7926053
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
