Hey all have a few bits and pieces I don’t need and taking up space:
Factory turbos  with dumps(no shaft play)$250
Factory blow off valves $150
Factory manifolds $50
Factory crossover/intake piping $100
Blow off valve piping $50
RB26 cam backing plate $40
3 sets of intakes 1 k&n 1 hks 1 unknown $150
Factory afm x2 $100
All oil, water and wastegate lines including banjos $100
Factory fuel pump good nick $50
Mines ecu $50
RB26 alternator $50
Fuel sender/ top hat unit $20
Charcoal canister $50
R32gtr washer bottle with motors $50n
Nismo fuel reg with standard rail and 11mm raceworks adaptors $150
Factory RB26 camshafts $100
Factory radiator with cut up shroud $70
RB26 sump with cracked diff housing $100
Complete RB26 sump suit rebuild with center and 4.11 gears $250
2 front diff centres $50 each
Front 4.08 ring and pinion $50
Late model r32 gtr 4.11 rear diff $1100
Borg Warner s360 .91 t4 spilt entry made 330awkw on 17psi $500
R32 3inch exhaust with xforce muffler $100
rb26 flywheel with exedy heavy duty clutch $150
Pick up only! Located south east Melbourne
Happy to do bulk deals
Message me on zero447086966 for pictures
Cheers
Edited by Pierreb
https://www.sau.com.au/forums/topic/479964-various-rb26-r32-gtr-parts/
hi mate I would like all the factory water lines, I would forsure add for shipping and your time. im in Canada..pm me if your interested I see some other stuff I would like but may be sold already. one of my stock pieces for the water lines I had to retap cause it was stripped so this would be a god saver!
sorry for the double post by water lines I meant everything you had together there for 100 including oil lines, banjo etc. not just the water lines. cheers m8
  • 3 weeks later...
price updates on what’s left
RB26 factory breathers with -12an fittings $20
Hks intake with k&n filtres $120
RB26 alternator $30
Nismo fuel reg with standard rail and 11mm raceworks adaptors $120
Factory radiator with cut up shroud $50
Complete RB26 sump suit rebuild with center and 4.11 gears $180
Front 4.08 ring and pinion $20
RB26 flywheel and heavy duty pull type clutch exedy fair bit of life left $120
Factory cold side cooler intercooler piping $50
R32 gtr washer bottle with pumps $50
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
