On 21/07/2022 at 5:24 PM, Kinkstaah said:
That reminds me, why did I use all of the ports on the valve covers when I could neaten it and just use the PCV like you have done.
Cause.. flow? Ugh. Looks nice man. Much nicer than mine!
I asked about this when Autotech put the blower on, this is the way Harrop has the installation, the drivers rear breather is plugged, the passenger rear breather goes to a PCV valve then the intake, the front drivers fresh air is still there plumbed in to the intake as well
I asked about if it would restrict the flow, both Harrop and Autotech said it was fine and a single 3/8" line is more than enough, because thats what it basically has stock, well, my rear main is still where it is meant to be, and the dip stick stays in its tube
The standard valve cover vents go from 2 x 3/8 to 1 x 3/8 line with a PCV valve  into the TB
On 21/07/2022 at 6:59 PM, Ben C34 said:
Why are you so worried about heat man?
It's not like they burst into flames. It is like 20yrs old and hasn't burnt down yet.
Because I'm bored and want to play around, plus they have heat shields standard
I assume an engineer smarter than me thought it was a good idea, and it got past the people holding the purse strings, so they thought it was necessary as well
I asked myself "why do OEM exhaust manifolds all have heat sheild, and why does nearly every modified car doesn't have one"
My conclusion for OEM was the smarter than me engineer senario above
For the modified cars, my conclusion was it doesn't add HP for the money and time, so alot people don't bother, until they melt wiring or other stuff
Meh, I've got a heap of the sheilding for a few attempts, worse case senario is I hate it and start looking at V4.0, or, some other random thing that the voices in my head think is a good idea.........
(I wonder what a 4" exhaust would sound like compared to the current 3.5" single ?????)
  • Like 1
The earlier LS1's do that, the newer ones (like mine) have the PCV valve in the valley cover, so the only hose they have stock is the under-valley one to the intake manifold.
My one came with a nightmare combination of both vents and a newer PCV. You need to have the one from the throttle body on. I plugged it and exploded my dipstick at the track N/A because I was thinking boost land with a one way valve. Well it turns out crankcase pressure when it builds vents in the other direction into the intake manifold, so it's both fresh air and a vent. So don't mess with that one lol.
  • Like 1
Found my next pointless mod
Purchased a RU-3130 for $50 with a 3.5" flange, LOL, I said flange.... >s-l400.thumb.jpg.eb2ca6d47f73db04ffae08b68a874e65.jpg
Plus some composite sheet and pinchweld to look like >
0e53602e-a8c4-439f-89c1-a4a9c0ed3d6b.medium.thumb.jpg.f2aae5c63b9cde1f35e8800693c93d9d.jpg
Why, maybe more induction noise, and a day of making templates, drinking beer and possibly even some wrinkle coat paint splashed about
  • Like 2
On 23/07/2022 at 12:31 AM, Dose Pipe Sutututu said:
Maybe you should buy Lego, same feeling, less money lol
Have you ever stepped on Lego?
That stuff is dangerous and I won't have it anywhere near me
Plus cars and motorbikes are like Meccano and Lego for adults
Going to WSID tonight with the boy for some passenger runs
Not going for gold, I'm going to leave easy with some minor mechanical sympathy
In other news, I have the local tilt tray guys number on speed dial 🤣
  • Like 2
On 27/07/2022 at 8:09 PM, Ben C34 said:
Nice, are you stalling it up or just mashing the pedal?
Often people stall it up and it hinders more than helps. Just mash it and see what happens.
Just mashing and pedalling it
I've still haven't had the RaceTCS fitted yet though, once that is installed it should knock some time off my 60'
Even 2 seconds flat on the 60' should get me into the 11's I'm thinking
The big old girl feels really good
Drag radials will change it, I mean if the 60ft becomes 1.8 you'll be down into the very low 11's to boot.
Then again after you have the slip in your hand you now have extra rims and tyres to stare at going "Ah yeah... cool, now what"
So may as well just do the math and be satisfied 😛
  • Like 1
I'm really happy with the car as it stands, the MPH shows hows that the car is making good power, but with the limiting factor of traction on the dig
I did umm and arr about drag racials, but I cannot really justify purchasing drag radials and rims to get a better ET, which like you said, would just sit a around for most of the time, the old girl was built to be a fun cruiser with some poke, not a drag car
When the RaceTCS gets hooked up I'll have another go and see how that goes IRT improving my traction on launch, my vision is a fast street car than I can drive up and down the coast in, and have a little fun with on the odd occasion, without worrying about needing to swap to drag radials to do it
I am happy to run the R888R rubber on the rear though, so far they are lasting really well, they have run up and down to Goulburn, Canberra, and Coffs Harbour a few times, and are just as good, if not better than the Hankook RS4's in the wet, and they have done alot of driving around in the wet, I'm hoping to get 10-15k km out of a set doing street duties
  • Like 1
Whilst I'm playing around with the car it would be unfair not to play around with the bike
My right heal would get rather toasty sitting next to the exhaust, even though it does have a shield, so, some heat wrap under the sheilding was called for, you cannot even really see it which is nice
I'm riding to Goulburn tomorrow so it should cure well and stop smoking by........ Marulan........
Just need to give the bike a clean, to ensure it rains today, and not tomorrow....
20220731_132203.thumb.jpg.d96d769c21ff5f9967fb389c9b292f93.jpg20220731_132220.thumb.jpg.be14714b5e57b1547ff41028e9742699.jpg
On 31/07/2022 at 2:17 PM, Duncan said:
My tip is....it's bogan cruise ship, not harley, weather down here at the moment mate
I've got alot of warm bike gear that can deal with the cold, and for the wet I've got good wets and warm waterproof boots
I'll will still be on leave next week, and I'm hoping that after hanging out with the daughter for a few days I'll go for an inland adventure, possibly to Walgett, then along the Gwyder into Grafton then the A1 into Coffs, it's a great ride on the bike
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
