22 hours ago, The Bogan said:
Thinking of going even taller in the rear end
3.07, or even possibly 2.87
The 3.46 gears are much better than the 3.91 that were originally in it, and for all of the hwy cruising I do, and with the amount of torque the car has just off idle, and the stalled slush box to get the engine spinning I think the longer gears will give me more manners down low, and good fuel economy on the hwy
I have a 4.11 in mine, and a .63 6th instead of a .50.
Even with these (relatively insanely) short gears, my 1000kmh idle is like 1800rpm. With the .50 it was 1600ish? With the rear ratios you are talking about, I don't know honestly why you don't get a 4cyl econobox and play V8 rumble through the speakers.
  • Like 1
  • Haha 1
  • Confused 1
How do you find 3 & 4 gear with the 4.11? especially on race tracks.
Looking at LS conversion for new car and hard to get info on the nissan 3.9, 4.08/4.11, 4.3 ratio with the 6speed
17 hours ago, The Bogan said:
And after almost hitting a roo on my last adventure down the coast I want one of these smart bar plastic roo bar thingies
Currently got the feelers out and on the hunt
They have been known to do more damage to the car than roos......
Insurance will cover repairs if you do hit one.
  • Thanks 1
Because I like 500hp v8 rumble
I'm at 2300rpm at 110kph with the 4l60e and 3.46
Meh, in the end the car is a cruiser with some poke, it isn't a race car, it doesn't get locked in a garage all week/month, if I can have it fast, and somewhat economical on the hwy I call that a win
I got you fam
Source: me doing what you doin. This is with limiter of 6600 and 265/35/r18 tyres, and a 4.08 rear.
So, turns out it is 2123kmh at 1000kmh. The regular T56 6th gear is 1696kmh in 6th. Making before what I said a little fake news.
Also I forgot it's auto, yet again. I also just realised that the numbers I pasted right now are a mix of 4.08 but the rpm at 100kmh is the 4.11 rear. Cause I clearly am not sure which one I actually have in my car cause it makes no difference unless you're doing it all in excel 😐 😐 😐
I find the ratios to be near on perfect - That said I bought the magnum for the 5th gear being shorter which makes a mental difference but testing it IRL and in simulators like assetto corsa showed actually no difference in pace 😛
^--- also me
  • Haha 2
3 hours ago, Kinkstaah said:
I got you fam
^--- also me
Thats the info I needed, Legend.
I better start looking for a decent LS conversion kit.
Damn it
Got a "letter" in the mail
80 kph in 70 kph zone late last month
It was on an off ramp heading off the M5 near Casula
1 point and $128, not a big hit cash or points wise, but I've lost my gold licence, Mark has a sad
New headlights as the current 20 year old headlights have alot of really fine cracks that don't buff out of the plastic
Do I really need them, nah, because really you can only see them in a certain angle and a certain light, but at $200 for the pair delivered "why not"
  • Like 3
Heading into Goulburn to lunch with the daughter
Ambient temp was 18°c
Pre interchiller it would sit around 35-40°c at the same ambient temp
The R888R's on the rear are performing really really well and have been surprisingly good in the wet and standing/flowing water (small rivers running across the Hume Hwy)
Bogan life is good 👍
  • Like 3
Gave the car a wash, wax and detail, and while I was buffing off the wax, that I seductively applied by hand, and I mean sticking my hand in the Meguiars tub of wax and then massaging it in lovingly into the paint work, I hooked up an old water bottle and drained the SAAS AOS
That's 5k km of blow by "stuff", not bad for supercharged old girl with nearly 150k km on it
After smearing love and draining blow the car spent the night gallivanting around in the city, ended up at the girls, wasted, and slept out in the garden, it is now covered in 11ty thousands of pine needles
  • Like 1
I was talking with the guy from Craigs Automatics, who built my 4l60e, about going taller diff gears i.e. 3.07 or even 2.87, there recommendation was not to go any taller than the 3.46 gears that are currently in it because of the current converter specs, engine power and the 3.46 gears
He believes the current custom billet converter in the 4l60e is near on being maxed out reliability wise for the current rear gears and power the car is now making, which makes sense as the converter was originally speced when NA for around 500nm (currently around 900nm "ish") with 3.9 gears, he said that going any taller gears would probably overheat the converter and trans more than the current trans cooler can deal with and it would end up in tears, on the side of the road, he recommended that I just get some drag radials and be done with it 🤣
So basically taller gears will require a new converter, but, as I'm a "while we're in there kind of guy" that could end up down the proverbial rabbit hole of the T400 with overdrive that keeps popping up in my feed, and is also blindingly expensive
I'm also trying to find some new R888R in 275/40 17 to wrap up and stash away for the future, the current set on the rear are at about 50%, so probably about another 5k km away from needing to be replaced, it seems like I'll get about 10k km from a set of rears, but, currently I'm struggling to find any on hand anywhere, I have got Tempe Tyres to give me a stock alert for when they get some more in
While we are talking tyres, I'm heading into St George tyres tomorrow to try and grab some Mickey Thompson ET Street 275/40 17 to put on another set of 17 x 9.5 Simmons FR1's for special occasions.......yes, I know.......LOL
It's like a disease 🤪and car parts are the cure
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
