Hello, sory for my bad english, but i need your help,
I am in work to remaking the engine of my r34 gtr, and I have a problem with the bearings
first question, the best bearings is nismo or other brand?
I have seen that there are many colors that coincide with the measurements, but unfortunately I have opened the engine and not on all the bearings you can still see the color,
how do I know which ones I have to mount where I no longer see the colors?
these are the measures I have taken
main bearing color:
1 green 2 ??? 3 ??? 4 ??? 5 maybe gold 6 green 7 green
main bearing dimension:
1 54.96 / 2 54.96 / 3 54.96 / 4 54.95 / 5 54.96 / 6 54.97 / 7 54.96
connecting rod bushings color:
1 ??? 2??? 3 ??? 4green 5green 6green
connecting rod dimenison:
1 47.96 / 2 47.95 / 3 47.97 / 4 47.97 / 5 47.97 / 6 47.97
how do I calculate which ones to order now?
thanks a lot to everyone for the help
i hope to finish soon my car and going in all europe whit my Sky  image.gif.c58bd52e8898da19a0dec6c0b564eb13.gif
https://www.sau.com.au/forums/topic/480114-help-for-engine-rebuilt/
Yeah the markings refer to the grades when it left factory. Best to accurately linish the crank for oversize bearings and just buy them at the right clearance. Most common option in Aus is ACL bearings but if you can get factory ones where you are that is an option. No bearing should be meaningfully "better", just get the clearances right
OP I believe RHDJapan has info on the Nismo color-coded bearings...however they are extremely expensive/overpriced. Even oem Nissan bearings per color size are very expensive, when compared to just a set of "Standard 0 size" .
The Nissan workshop manual refers to bearing colors but I only have the r33 manual, not sure where you'd find one for the r34's rb26 specs.
You will note though the tolerance for the different sized bearings is extremely tight...which is good, but I just used a set of Standard-0 rod and mains bearings in previous builds/freshen-ups when no machining work was done, and clearances have been fine.
7 hours ago, street performance said:
yes, but i need to order now the correct, i have take the measure
Try to download an engine workshop manual - it gives all the specifications for rebuilding.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
