Just bought a RB26 that the buyer claimed was a R34 engine. I’m confused because it has the black CAS and the red valve covers with Skyline GTR emblem plate, but it has and igniter and the older coil pack design. From my research this combination doesn’t make any sense. Out of all the threads I found about the engine numbers it’s seems that the first number correlates to the year. Can someone look up the number still?  RB26 072998A.
https://www.sau.com.au/forums/topic/480125-help-identify-my-rb26/
The number does not correlate to the year, they are just consecutive numbers
There are probably lots of little changes along the way in different series. Easiest one I can think of it here is a sump on it is that R34 had a much longer diff ratio that the 4.1 in r32 and r33.
But ultimately, other than knowing if the buyer was honest I'm not sure why it would matter. They are mechanically same same one the inside
45 minutes ago, Rickyv42 said:
Yeah it came with the R33/32 coil packs and an igniter.
Did it come with a diff and did you check the ratio (although I presume you can bolt an R34 diff on to an R33)?
Yeah you can (why would you?), but you can't go the other way though. Can't bolt the bigger R32/R33 4.11 crown wheel into the R34 smaller front diff housing in the sump.
Who cares though, late 32/33/34 is all the same block / bottom end as Duncan mentioned.
34 head casting is the same as the rest but the exhaust camshaft is different on cas drive, requiring the later cas. That said the 34 cas can be modified to fit the 32/33 cams, so you still wouldn't know what's up without pulling stuff apart.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
