One big thing people leave out about e85 is the amount of fuel you use vs pump. I have done research and talked to people and for a street driven car to and from work and the shops it was way out. I get flex fuel and running a pump tune and a e85tune.
im still running 1000cc injectors, Steve thinks they will be done with water meth. I know for that 1000hp number e85 will most likely have to be used to get the bang going
Yep this is 100% accurate, you'd not want to run E85 to and from work.  The extra volume of fuel you need with ethanol goes up steadily as the blend increases, and that extra fuel usage impacts "just cruising" as well.   You definitely need a big fuel system if you want to make 550+kw on E85, though really if you want 550kw+ then you're probably a bit in denial if you think you can cut costs at this stage.   Block strength is potentially coming into question, OEM Nissan gearboxes are at the end of their line, the whole build has to be pretty serious at this stage.  Going a big fuel system when planning for 700whp+ on a smaller RB is pretty incidental in the grand scheme.
This still brings back the "but run flex fuel" thing, if you are aiming at commuting etc you probably don't want/shouldn't have methanol just sitting around in the car waiting for you to thrash it.  There is the clear bonus that you don't use it when you're just driving it normally, but then also you don't want it to get contaminated over time or even lose track of the level.  It's an extra thing you need to keep an eye on... the flex fuel idea again is one where you only put ethanol in if you want to get up to no good.  By E30 you have really good gains and the impact on fuel economy isn't actually that nasty by that point, if you want to get real fancy for an event then you can try and get it up to E50+ but you don't need to measure or think about it.
After that, keep putting normal pump gas in it and it'll gradually dilute itself down to E10 or less as you top up with pump gas and the tune will dial itself down to suit.   If you have a build that is going to make 550+kw on E85 then it's not going to be gutless on a pump gas friendly tune, and with flex you don't need to keep topping up the WMI, you don't need to do anything special.  Just drive the car and the tune will make sure everything is safe and well.    That's the kind of reasoning we've used at least :)
But yeah "for now" I'm sure if you can do the 550kw power level with pump and WMI and the 1000s  then it's at least a good stepping stone.
Gearbox, drive shaft and axles have already been swapped out for bigger and better items.
This tune is just that another stepping stone to the main goal. I’m not one to go all in at 1000hp and crash the thing. With each upgrade I need to re learn and get used to how the car feels. Once this step in done the final step will most likely be e85 and a full re work of the fueling system. Baby steps to get used to the power
  • Like 1
Sounds like a solid plan :)  Its going to be a monster as is.
  • 3 weeks later...
  • 3 weeks later...
  • 7 months later...
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
