I shouldn't think so. So long as what the Regency boys would consider the "emissions controls" are all in place then an FFP is not really changing anything that they would be upset about. Of course, that then opens up a whole can of works, because there would be little point in putting an FFP on a car that still had all it's original emissions controls, which includes the unmodified ECU.
Once you have a bigger turbo, to justify the FFP, and possibly a different throttle body, and at minimum have Nistuned the ECU to handle these changes, you are no longer "legal" and would need full engineering of the mods to not be defectable. And of course, engineering for ECU changes invites the emissions testing saga, which is $$, etc etc, blah blah.
The other aspect of an FFP on a Skyline is the problem of cutting a hole anywhere to pass the intercooler pipe through on the driver's side. Most such holes are defectable. It doesn't matter how "non-structural" you think any particular piece of steel is in the front end, they say that it is part of the original crash structure and cutting a hole in it will change the crash performance.
  • Like 1
My curren engine bay, wanting a clean look.
After some ideas how to clean up a 32 gtst engine bay.
So far I'm welding all the holes up, re routing the brake lines, shifting the battery and windscreen bottle to the boot and shifting the fuse box to under the dash.
aren't the rules here 2 intake mods allowed fmic and pod filter would take it up
but yeah safe to say it'll be a defect anyway seeing as they can get you on suspicion anyway.
Good to see you're still kicking around in 32 land
No, that's Victoria. SA has always been far more reasonable. Not necessarily easier, once you actually do change stuff, but definitely more reasonable. Hence my authoritative statements in my first reply.
good to know. i was just speaking from past experience where if it looks modified they are well within their rights to send it for inspection.
though i did find this on the SA.Gov.au site. https://www.sa.gov.au/topics/driving-and-transport/vehicles/vehicle-standards-and-modifications/engine-and-exhaust-modifications
No alterations to the engine's camshaft, inlet manifold, carburettor/fuel injectors, engine control unit or the catalytic converter are permitted.
Modified or aftermarket plenum chambers or throttle bodies are not permitted.
2 minutes ago, GTSBoy said:
Ooh. I would not have expected that. I wonder when they started saying that? It's been a few years since I last spoke to anyone at Vehicle Standards.
yeah its odd that it specifically mentions plenum chamber modifications. someone must have done something to get them to specifically rule it out.
maybe it was those hidden NOS ones haha
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
