Does ISR make good quality fuel injectors? I'm also curious if they are compatible with the Radium top feed fuel rail that I bought. I'm looking to buy some for my RB25det http://www.isrperformance.com/isr-performance-top-feed-injectors-750cc-set-of-6x/ and was wondering if this would be a good purchase. I'm shooting for ~400hp.
https://www.sau.com.au/forums/topic/480391-isr-injectors/
Yeah they look like they should fit no problem.
I would think about getting something a little larger though, around 1000cc just to keep the option of E85 available in future. While those injectors can do 400hp on E85, they'll be close to their limit at that stage.
Sorry can't say if those injectors are good or not, never heard of them.
A set of Injector Dynamics ID1050x Fuel Injectors are only about $100 (USD) more then those ones and are a proven thing, I'd be looking at going with a set of ID1050x.
https://www.sau.com.au/forums/topic/480391-isr-injectors/#findComment-7930954
As as general rule I do not recommend buying any injectors that lack a diffuser plate. Also if you are concerned about transient fuel tuning you want to avoid the ID injectors, if you talk to Adaptronic they have mentioned that the wall wetting effects are much stronger with the pencil spray pattern used on the ID injectors when used in 4V DOHC setups because much of the fuel goes straight into the divider between the valves.
If you want to run E85 at all just go for the Bosch 0280158040 injectors, I believe NZEFI sells them with some adapters to be a direct fit for RB25DET with top feed fuel rail.
  • Like 1
https://www.sau.com.au/forums/topic/480391-isr-injectors/#findComment-7930957
Google will explain it better then me, but roughly, e85 has a lower energy content so more is needed compared to pump 98. Expect to use an additional 20% to 30% more fuel compared to pump 98.
It is worth running, but you just need to size your fuel system appropriately for it.
https://www.sau.com.au/forums/topic/480391-isr-injectors/#findComment-7931076
6 hours ago, Jason062100 said:
The Injector Dynamic injectors have a horsepower range of 800-1200 HP, 1000-1400 HP. Should I go for something within my range?
Get the Bosch ones ...they will operate satisfactorily at low flows as well as at maximum.
https://www.sau.com.au/forums/topic/480391-isr-injectors/#findComment-7931080
http://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
these are the ones I was looking at. Are these the ones you are referring to?
https://www.sau.com.au/forums/topic/480391-isr-injectors/#findComment-7931083
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
