In the process of having my engine built (Rb26 on a GTR) - Forged Pistons rods etc, and with 9.0.1 compression. Bought what i though was -5 turbos, but now re-looking at the tag Im not so sure?
The Tag is GT2560R 707160-5
Comp housing is stamped with .60, rear is the normal .64
I've heard that the GT2560R is the re-tagged GT2860, but also appears to say that a 2560R is a Garrett equivalent 14411-AA403 OR it could be a -7
GCG turbos have that tag ID as the -7
https://gcg.com.au/Turbo-Charger-GT2860R-AKA-7-Nissan-Skyline-GTR-RB26DETT-G836026-5004S.html?ref_cat_id=26
And the below site has the GT2560R as part of the Nissan "replacement" range.
http://www.capa.com.au/prices_turbo.htm#turbo_garrett_medium_frame_ball_bearing
Anyone have some knowledge on the old tag numbers?
Edited by djvoodoo
For anyone wondering, did a bunch of searching around these GT2560R's. They do look like the larger 34N1 equivalent with the .60 comp housing. So not as big as -5 or HKS2530, almost an in between between -9 and -5?
Some people say Garret just rebranded and changed to 2860 instead of 2560, some say it's a difference between OEM vs aftermarket.
Found an old comp/turbine map someone posted on SAU back in 2013.
I have -9's currently, and here's hoping these will outperform in overall power with similar response to -9s... (looking for 360kw on 98 on a built motor with 9.0.1 comp)
  • 6 months later...
I had these on my R32 GTR. Definitley smaller than the 2860-5's I have on my R34 GTR. They're a great turbo, mine made 340wkw at 20psi on 98Ron on the RacePace dyno with a built 2.6 and Tomei drop in cams
From memory the GT2860R , at times known by the original part number 707160-5005S , is more like what HKS called the GT2530 .
Old news now but back in the day (1991 odd) the GT25xxR ball bearing turbo reference related to all with GT25 and GT28 turbines .
So the HKS spec "GT2530" actually has the GT28 76 trim turbine , same as your GT2860R 707160-5005 units .
The main difference is the compressor which is 60 odd mm 63 trim , and 62 trim in the -5005 ones .
From what I can gather the "-7s" look more like a GT2560R and appear to use the slightly smaller and different style 53mm 62 trim turbine , also the 60 odd mm 60 trim compressor . I think I found a reference and an OE Nissan like part number for the -7s so could be the R34 N1s . They would have been an upgrade on the std R34 GTRs ceramic turbine units .
All these are old part numbers now and could have all changed over to the 8mm type turbine shaft and G series style ball bearing cartridge .
The older Turbo By Garrett catalogues covered most of these except the HKS specific turbo and cartridge numbers but I have old lists from years ago if anyone wants part numbers .
At the end of the day I'd err towards the "2530" or the 707160-9s given a choice because at least they were developed to suit RB26s . Garrett made the HKS spec BB turbos and could not initially sell these units or cartridges for some years . So they decided to market units similar but not quite the same .
Cheers , A .
  • Like 1
Type B drop in cams. 260° intake and exhaust with 9.15mm lift. Stock R34 GTR crank which was a new item, Eagle rods and CP Pistons in a N1 block. The motor was built in 2009 too. Was a good setup with the gearing on the 32. A bit laggy in a hairpin but otherwise really good. Plus made decent power on a safe 98 tune so cant complain.
I have since sold these, but there was alot of confusion. I emailed Garrett and was told the GT2560 IS the -5. I can also confirm that the turbine exducer is 47mm, the same as the -5. The -7 turbine exducer is 5mm smaller.
Well whoever you emailed at Garrett is wrong .
That pic shows a GT28 NS111 turbine in 76 trim , inducer around 53.8mm and exducer around 47mm .
Also have a look at the pics of the turbine maps above and the associated details .
If you think I am wrong look up the specs of the GT2860RS and GT2871R series turbos , these and a few others all use this same turbine - well turbine wheel anyway .
The basic GT25 turbine should measure approx 53mm  and is 62 trim .
The term GT2560R is a generic one . It breaks down to GT for Garrett Technology / 25 for the turbine series / 60 for the compressor OD / R for rolling element ball bearings . There are many variations in housings and compressor wheel trims . Honestly the best way is to search for cartridge numbers because the details will show turbine and compressor dimensions .
A .
A .
I emailed both Garret (USA) and GCG. They both said the same thing, that it is a-5 and the tag association of GT25** and GT28** is somewhat of an argument.
Not saying you are wrong man, just going off the *experts* advice and the physical measurements i did of the compressor inducer and the turbine exducer using verniers.
I put them side by side a set of HKS GTSS turbos and i can say that the 2560 was noticeably larger in every way and matched the -5 specs.
Here's another thread with a brand new turbo marked as 2560:
Edited by djvoodoo
If you are speaking about RB26 spec GTSS turbo dimensions then that is correct
Just for another layer of confusion there was also an SR20 spec version of the GTSS but it had the larger NS111 53.8mm 76 trim version of the GT28 turbine . Same as your turbos had .
Back to the RB26 style GTSS turbos . These use a cropped version of the GT28 NS111 turbine so they'd measure 53.8mm 62 trim . The smaller trim means they have a smaller exducer and outlet diameter than the 707160-5 turbos .  Also to these part numbers . Often on the turbos ID tag there are inconstancies . For example one of these turbos may have 707160-5 , another identical one may have 707160-5005 . Often people , and Garrett , quote turbos by a dash number ie -9 or -7 or- 5 . It makes life difficult .
Anyway the best way I can describe GT25 and GT28 BB turbos is by their turbine dimensions and their number of blades .
11 blades can mean GT25 OR GT28 turbines . The 53mm outside diameter ones are GT25 . The 53.8mm outside diameter ones are GT28 . The GT25 11 bladed turbine is generally 62 trim . The BASE model GT28 turbine is also generally 62 trim .
The GT28 NS111 9 bladed turbine , remember - GT28 turbine 53.5mm OD ,  comes in two trim sizes . Most were 76 trim BUT there was a special version in 62 trim for specific applications . Note that this NS111 62 trim turbine has almost exactly the same dimensions as the 11 bladed GT28 turbine - 53.8mm OD 62 trim .
As far as I know the cropped 62 trim NS111 turbine was only available in two turbos , firstly the  RB26 style GTSS/707160-9/707160-5009 (all same) , and secondly the GT2854R .
I found a link to details of that GT2854R and they kindly have pics of the differences between the GT2554R and GT2854R turbines , totally different 11 and 9 blade forms .
https://turbochargerspecs.blogspot.com/2011/03/garrett-gt28r-gt2859r-56-trim-310-hp.html
Cheers A .
  • Like 1
Sorry people bum steer , that link was to details of the GTSS/GT2859R .
https://turbochargerspecs.blogspot.com/2011/03/garrett-gt28-gt2854r-270-hp.html
This one should take you to the GT2854R and note the second and third pics of the turbines .
A .
  • Like 1
I recently bought a set of twins which are advertised as -5's but on the turbine housing it is stamped 0.48 A/R yet advertised as 0.64, Anyone know what's up with that? Here's the box they came in:
This is a link to a more recent Garrett catalogue and the unit of that turbo part number .
https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/gt2860r/
It doesn't look like the part numbers mentioned above because these have an updated center section and bearing pack than the earlier GT/GTX gen 1 units .
I'd take it up with the supplier .
I'm not too fussed about it, I just thought I would add to the confusion. Physically these -5 turbine housings look to have a bigger snail when compared to stock R32 turbos but definitely have 0.48 A/R on them.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
