47 minutes ago, joshuaho96 said:
I'm actually just hoping to be able to get an RB to be more modern, running something like high 13 AFR deep into boost and revs instead of 11.5 and maybe push back the knock limit enough to get power equivalent to 98-100 RON fuel with 95 RON. RBs also seem to be thermally challenged so water injection might help in that regard as well if it ever makes it to a track. But if the trade-off is I never actually get to drive the car or I have to pull the engine because water contaminated the oil and trashed the engine it isn't really worth it.
You are a funny guy
  • Haha 1
E85 done, less thinking and stuffing about.
You can put timing way past MBT and start losing power on a RB with E85 and it won't even produce any knock.
Anyways back on topic, 10:1 would be sexual. I would still keep the squish pads in there though.
Disclaimer: Not a professional engine builder. You'll need to CC your parts to verify these calcs, this is assuming the stock Neo head has a 51cc chamber and you will also want to verify piston to valve clearance.
Playing around with a compression ratio calculator (I've been using https://goodcalculators.com/compression-ratio-calculator/) I'd say an 8.5:1ish R33 RB25DET piston would be a good starting point. I can see two fairly easy/reasonably cheap options so far:
Option 1 - ACL aka Ross aka Mahle 6MKRY9603 with 11.5cc piston dome. Set to zero deck height with a 1.3mm head gasket on a Neo head this should give a flat 10:1. If you bring the pistons 0.5mm above deck you can achieve around 10.5:1 with the same 1.3mm HG while keeping quench around 0.8mm - I've heard 0.7mm-1.2mm being a rough rule of thumb to aim for. Each 0.1mm gasket change on this combination is roughly 0.15 change in CR so you should be able to fine tune the CR easy enough.
Option 2 - Wiseco K578M865AP with 14cc piston dome. At zero deck this will give 10.4:1 with 1.3mm HG. With +0.5mm deck height this will give 11:1. As before a 0.1mm change in HG thickness will change the CR approx 0.14-0.15.
Hopefully this gives you a starting point.
  • Like 2
2 hours ago, Ben C34 said:
You are a funny guy
I like to spend my hours reading about interesting things, not necessarily productive though.
Feels like this has been the answer a number of times I've looked into this. I'm probably going down that road in the end, just want to figure out a good 340 lph brushless in-tank pump solution.
Walbro F90000267 and call it a day (or F90000274 if you're running stupid high base pressure & big silly boost)
That is a properly buff pump but probably too much fuel pump for something making 300 kw. Something like the Fuelab 48402 seems to be what I'm looking for, around 10A draw and capable of 300 lph at 70 psi outlet pressure to be able to turn up the FPR to 3.5 bar differential pressure. I might run some experiments to see if the OEM FPCU/FPCM has the right resistances to be able to actually function as the pump speed controller, have to see what the impedances look like. Probably have to just accept that it's a horrendous idea though and just use a standalone ECU to run the PWM controller.
Anyways, I don't doubt that high CRs improve driveability, I'm just skeptical that you can run high CR with low duration cams and no tricks like advanced VVT/cooled EGR/E85. I'm sure that Mitsubishi and Nissan would've raised the static CR on the 4B11T and VR38DETT to 10:1 if they could've done so while meeting power targets on pump gas. The VR30DDTT has a 10.3 CR but uses GDI and dual VVT to get there.
Don't waste your time, you'll end up killing the pump with the OEM setup. PWM is the only way, not a drop resistor (like how the OEM garbage works).
1 hour ago, GTSBoy said:
Emissions.
Doesn't that imply that you would have to run rich for too much of the load/RPM map? Modern gasoline is up to 14:1 CR for NA, or even as high as 16:1 for the Skyactiv-X, as high as 12:1 for turbo. I can't think of why emissions would factor into it. NOx obviously goes up with high CR, but 10:1 PFI-T is nowhere near what diesels have done for a long time now.
You're knock limited with port injection, thus running it leaner is not possible. With direct injection you get better atomisation, cooling effect of fuel being compressed at high pressures then decompressing in the chamber, thus your knock threshold is much higher.
Doesn't this imply that you would want less CR anyways? I can't imagine running rich all the time is healthy for an engine.
NOx is the big one.
Diesel combustion temperatures are quite different to petrol, both at partial load and at full load. Diesel runs very lean at partial load so has different NOx problems than petrol does. Hence why they're down the Urea injection rabbithole these days.
For OEMs trying to meet Euro and US emissions regs, fuel consumption targets, engine life expectancy & warranty boundaries, the space they have to work in is a very tiny portion of the N-dimensional space. So they can't have a combination of high SC and boost and not give up ground in at least one of the other dimensions of their design space. It's a bigger nastier version of "cheap/fast/light pick any 2".
  • Like 1
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
