23 hours ago, JohnnyR31Silo said:
Another question I have I wanted to get a 2.5 inch exhaust for my r31 just wondering if use know a good site to order them off or a certain brand..? Iv been told eBay but thought I’d ask use first
Get a local exhaust shop to fab up a 2.5" mandrel bent cat back using two quality mufflers. Will sound nice and you might make an extra 1kW up top.
  • Like 1
Sweet as will do cheers, another question sorry if I’m doing heads in.. I wanted to improve the air flow I was gonna do a basic pod filter but my brother was telling me to get a growler kit any thoughts ?
If any thing don’t worry about the exhaust just found out if I’m going to turbo my car I’m gonna need a bigger exhaust 2.5 inch is no good, would a growler kit be okay with a turbo though?
Do you reckon a growler kit would be good for a r31? Especially if I’m gonna turbo it eventually would I be able to keep it on or no?
What? no
best upgrades on my R31 are:
good tyres
working dampers
GTS/HR31 front brakes
manual conversion
3.9 auto LSD diff that doesn't whine
GTS1/mild cam
  • Like 1
I was going to get the exhaust but a mechanic told me no point wasting money if the car is non turbo and Your planning to turbo it then a 2.5 inch exhaust is waste of money because I’ll need a bigger exhaust...? Is that true?
@Ben C34 very true, but if I’m gonna spend money I don’t want to be wasting it to much only want to get things that I need an if I’m gonna turbo the car no point getting a 2.5inch exhaust only thing is I’m trying weigh up is if the growler kit is worth it..? If I get it will it be the same thing with the 2.5inch exhaust..? If so is there anything I could do to the car that will help the air intake and what not without it getting in the way when I eventually throw in a turbo kit
If you're going to turbo the car, your first step would be to put the turbo on the car, and then get all the associated parts on it to support it (exhaust, injectors, fuel pump, ECU, etc)
What ever this growler kit is won't help you in that endeavour
  • Like 2
Turbo + fuel system + ECU + intercooler + pipework + exhaust manifold + oil&water plumbing to/from turbo + exhaust + dump pipe + installation work for oil supply and drain, etc. + tuning.
The list really should include upgraded brakes.
Oh, and you're in Victoria. So what you are proposing is not road legal. You will need to pay for engineering.
@GTSBoy I would want it to be street legal
I’m trying to make it full on just basic turbo an psi and what not.. even if you can recommend a garret turbo would be much appreciated.. I know there’s different sizes an what not so if you can recommend one that’ll fit good an wont go to hard to not be street legal
Iv been looking around found one on market place he reckons it came off a Jeep commander an reckons it’ll be good for a r31 but I’m not sure which is why I’m showing you guys
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
