Hi guys, I just came across a complete front subframe assembly for an r34, the title of the ad just says r34 so I’m presuming it’s a coupe. I have an R33 at home and was wondering if the r34 front subframe assembly will bolt straight into the r33. Im looking to do this with relatively little modification of its needed, also does anyone know if it will throw off the geometry of the car or if it’s okay to be doing this. Thank you very much if you’s can help guys :).
Edited by AshtonR33
Forgot a detail
They are very similar, but I don't think this has been done before/information is readily available.
I know there are *SOME* differences in arms between a 33 and a 34 in the front. Ostensibly they are different for 'some reason' but I don't know if the front subframe is the reason for it. I have bent knuckles and front arms before and found out that the 34 ones have curves in them where the 33 ones are straight. But you also have things like 33 coils fitting in 34's and vice versa (at the front only) and sway bars (I think)
34 coupe and sedan are the same at the front, but as the front subframes generally dont get uh, broken? It's not something that generally gets swapped between cars..
Oh okay, thank you for the information. It’s just because I’m looking to get my r33 on some wheels and came across an r34 front subframe complete, for a reasonable price and was just seeing if they were compatible with the R33 haha.
thank you though :)
  • 8 months later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
