Hi all, I am now running atr45sat with stock dump, hks front pipe, stock cat(empty inside ) , trust pe2 catback on my gtt. Only manage to get round 350 [email protected] told me to the main issue is the dump pipe. I have a few options in my mind now, wishing to seek advise from experts here.
1: possible to get a 3inch elbow dump (tomei/hpi) to pair up with my hks front pipe and  a xforce  hi flow cat?
2: hks elbow dump ,hks front pipe ,xforce hi flow cat.
3:tomei/hpi elbow , with Japspeed full 3inch front pipe, xforce hi flow cat
my concern is the fact that the inlet of my hks front is 2.5 Inch, only the outlet is 3inch, if I use a 3inch elbow, will it affect the flow? (That’s why I am contemplating to get the japspeed front pipe, looks like it’s 3inch both inlet and outlet )
Ps:due to local authority restriction , I need to have my cat intact , and I cannot do ewg.
any advise will be greatly appreciated
Edited by gimmelovetattoo
Well, it’s really a pain in the ass for car modification here. Yes I can run a cat with single piece bell mouth, but since the oem part come with elbow and a connecting front pipe, I am not allowed to change to a single piece . Therefore my options are limited , and I wish to make the best out of the limited options, so any more advise will be greatly appreciated !
Fitting a bigger turbo is somewhat in the grey zone, usually if it’s still on factory’s mounting position, you can get away with it. As for the exhaust system, they are super strict with it, we are only allowed SOME jasma approved catback . And as for front pipe, I am using hks, but I wrap it with the stock shield . I am located in Singapore .
That's our GTSBoy, doesn't just think outside the box; he cuts the box in half and puts a flange on it. Ideal way to go.
For a real oem look, you could even weld on some brackets to the dump and bolt the stock heatshield to it....possibly.
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
