Hi All,
I decided to paint my rocker covers with a aerosol can I had for the last 6 months, I de greased and lightly sanded the bad spots then scotch brite all over, I then gave 2 coats of primer & let it dry, I then gave it two coats of Matt black & let theist dry, then put on two coats of watermelon megashift pearl and to finished I put two coats of lacquer, I was very happy with how they turned out considering it was done in my shed on a cold night with aerosol cans,
I pulled the old pvc grommet and the two pipes from each head and put in An-10 adapters ready for the lines to go to the catch can, I cleaned the old sealant from the front and rear of the block and removed the 2 half moons as billet replacements and a head bolt kit to replace studs and washers..
on installing the half moons I put a healthy amount of sealer on and sat them in, I noticed that they don’t sit flush with the head, is that normal??
I put some sealer on the back portion of the head covering the half moon and along the front of the head.. I replaced gaskets with new ones just to be sure!! All was looking good at this stage..
but then ....
As I was tightening the rocker cover studs my brother said that will do as moments earlier I said they only had to be hand tight, me being me I gave an extra turn and all CC I heard was “ding” I looked down and it was split 🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️..
After a lot of swear words we walked away for an hour or two then I started the car to see if it would leak under pressure and surely it was 😭😭😭..  I noticed that it was leaking from the half moons at the rear too!!
I have sourced some rocker covers and will have to start again..  Any ideas why the half moons don’t sit flush and why the sealant didn’t seal & the rear of the head?? It did recommend 24 hrs but I’ve also heard people doing this job and driving straight away..
Any info ?? Did I miss something along the way??
Yeah but if you ever order from efi solutions, get some of their aluminium ones. Only a few bucks, fit perfect, haven't had to touch them since were installed, and have had rockers off/on 4 times since then.
  • Like 1
How much sealant did you put on them?  A smear or a healthy amount....
I assume you're referring to the rocker cover bolts. Was this one if those cheap shitty solid washer type kits that don't use a factory style rubber crush insulator ? If so, there is a reason the factory use these rubbers - to try and prevent overtightening.
Also the torque on these is only 2 - 4Nm.
Use the new factory stuff instead of the bling stuff - and actually torque them down in sequence. Not that this mattered in this situation with regards to sealing as the rear of your covers were kicked up by the billet half moons not being flush anyway.
  • Like 2
5 hours ago, hardsteppa said:
Poor design? Rubber ones sit up a little bit like that cos they can squash flat. My Taarks aluminium ones sit flush.
I’m not sure, I purchased them from Franklin performance along with the head bolt kit
3 hours ago, GTSBoy said:
The cost of copy engineering instead of proper engineering.
I may have to agree on this.. I will get some rubber half moons I think as said, as they can squash down.
I dont use sealant ben, i use my own various bodily fluids.
Wasnt tons, enough to give a little 'squeeze out the sides'.
  • Like 1
3 hours ago, Ben C34 said:
I wouldn't be surprised if by "healthy amount of sealer" you put on way too much and that caused them to sit high
The sealer I used was like a liquid and came with a brush in the pot, I put a healthy amount on around the half moon to try get a good seal so it didn’t leak but the height wouldn’t be caused by the sealer imo..
I got the bolt kit from Franklin performance, they came with small washers but are not the crush type,, I will try get some new factory bolts from somewhere or re use the ones I took off.. cheers for the sequence! I did tighten from the middle to each end, I will make sure not to use a ratchet and only tighten by 🖐 once the replacement covers get delivered this week.
I have a set of Franklin engineering billet half moons here. Didn't end up installing them but I did place them for reference in an RB26 head when I was going to.
They sit flush.
  • Like 1
Ah that’s my problem then.. I have just noticed the gaskets are different too 🤦‍♂️ The neo ones have a flat edge where the normal rb are rounded.. I’ll use the old gasket as it seems to be in good condition.
Ive changed all 6 spark plugs as the old ones were looking dirty
I have just bought some skyline r34 gt & gtt rb25neo genuine cylinder head half moons,
just waiting on paint to be delivered then it can go back together,
cheers for all the help and info!!
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
