Hi everyone,
I hope everyone is having a good day as a skyline owner ( or enthusiast)
I am having a very difficult time with my cluster at the moment. Here are a list of sections to my predicament:
- None of the gauges work (except the turbo gauge I think)
- The lights on the cluster will light up (handbrake light, check engine, battery etc. when I stall) but are not on regularly
- I have sent the cluster to a specialist in the Eastern Melbourne suburbs. He took it all apart and said he could not see any issues with it
- I have sent the car to the Auto Electricians in the Eastern Melbourne suburbs too, they had a look at the wiring and said they could not find anything wrong either
- The car does not have a Speed Transducer in the car at the moment. I have bought one but have not yet fitted it.
This leads to my questions.
If I replace the speed transducer, will this fix the rest of the issues on the cluster? I was hoping that it maybe completed some form of a circuit for everything?
Could it be the ECU? as far as I know I am still running the stock ECU
https://www.sau.com.au/forums/topic/481595-r33-gts-t-cluster-issues/
So the auto electrician says the wiring is ok ? Yes ?
That was their exact words ?
 And the "cluster specialist" said that all the instruments were working ? Yes ?
Again exact words ?
Then my money is on the flexible plastic circuit board sheet on the back of the cluster.
It may well have some breaks in it.
Can you change out the entire cluster ?
Hi @PLYNX
They did, they both said they could not see any issues with either the wiring or the cluster. The Cluster guy took it all apart and had no issues with it. The Auto Elecs tested the wiring and said they couldn't find any issues.
That is a good option, I hopefully can find one to buy in Melbourne. Have you heard of this issue before or just an educated guess?
Thank you regardless mate it is much appreciated
Yep had something similar happen to my R33 but not to the extent of problem with yours.
Changed it out, to test it, and it worked fine and then went over to a Veilside cluster and had a instrument repair place change the kms to the same as my original one( had to sign paper work for them )
Only other time I've seen a similar thing is a NISMO 300km/h cluster fitted to a manual that came out of a auto.
Fitted up It wouldn't work properly on the manual and when re-fitted to the auto worked fine again
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
