Hello. I have recently bought an RB25. It claimed to have poncams but no specs were available. Removed covers to find both intake and exhaust are 264/264 with 8.5mm lift.
Looking to degree the cams- but I can't find any info on a 264 intake and exhaust.
Are these real cams? Or knockoff? Never heard of fake camshafts but there is fake turbos so it's arguably easier to fake cams...
Cheers!6B0C81AD-4D30-45C5-B6DB-3DDDF8131D69.thumb.jpeg.6ca6daeb767c5dfae92fb0ae3b8da4ec.jpeg
https://www.sau.com.au/forums/topic/481662-fake-poncams/
1 hour ago, r32-25t said:
He retired last week or the week before
Really ? That sucks, they had some really good grind selections. Only just sold some new Camtech RB26 cams last week for $500. 🤦‍♂️
Kelfords only now I guess ?
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944615
Just now, CLEM0 said:
They certainly don't seem current- but I can't find any specs to degree them in!
Just put them on the same LSAs as any other 264° cam, or choose an LSA halfway between the typical 256° and 272° cams' specs. Tighten or widen the LSA by a degree or two depending on how you want the engine to work.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944623
Ages ago I was told that Tomei cams don't need to be dialled in and should always be set to zero ...for RB25 Gtst's.
This was after we dialled in [from memory 5 degrees [could have been 10, it was 20 years ago]] and it ran like shit.  Asking around everyone said to set to zero and it will work.....we did, and it did.
I could be wrong for your motor, but if you don't see gains then zero is your answer.
But Dose Pipe and GTSboy will know more.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944624
Yeah I heard that too- but these seem fairly big for what most run. Probably going to get some stock cams for now- runs like a dog off boost and isn't fun, 120psi across all 6, shitty idle etc
Likely they are 0* right now- no adjustable cam gears so I think for street use stock is fine.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944626
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
