My 33 has been making just over 400rwhp for at least 2-3 years now, unfortunately recently it has started to push out the dip stick. I have tried to leviate the issue but installing a better flowing catch can, rb26 covers with better baffles and it has helped, but my catch can is now filling up with about 3l of oil every 2000km (have to keep topping it up every week with about a litre of oil too).
Unfortunately I think it's time for a rebuild. Still not sure if I want to sell the Skyline as it is starting to cost me a lot of money and stuff keeps on breaking. I've just put a new gearbox, steering rack, accessories on the motor, rebuilt the front and rear subframes, new coilovers, new diff centre.
Would I be able to buy some 20 over pistons and just have the block decked and bored out to fix this? Or should I go ahead and put new rods, pistons, oil pump etc in and how much would that cost approximately?
Local shop wants $15k if I pull the engine out.
Yes, because that will fix the cylinder sealing issue.
Yes, and it will cost whatever your parts cost is, plus a few grand. Your parts cost will depend on how baller your parts are.
$15k buys pretty good parts and work for just a bottom end freshen up. But it is impossible to say whether it is good value or not without a complete list of what's included in terms of both parts and labour and machining.
At the moment I don't want to spend a lot of money on it, I don't know how much longer it will last.
I was looking for the cheapest option possible, second hand motors are a waste of time now as generally they would be worn out too.
I think deck, bore and pistons will be the cheapest?
Yes, but....make sure that you are prepared for bearings, because you will be exposing at least the rod bearings and when you do and find that they are f**ked, you would be equally f**ked (in the head) to put them back in that way. And if the rod bearings are f**ked, there's better than even money on the mains.
And.....front and and rear main seals, plus a timing belt and a water pump, because you would also be insane to not replace them while access is easy. And look for broken exhaust studs. Plus a full gasket set, etc.
Make sure you have the money required to put it back together ready, instead of sitting in a pile of parts until you scrap the whole lot!
There are still good wrecker motors out there. I would expect that you'd be able to find something decent for around the $2,000 to $3,000 range. If you can do the swap yourself that would be the cheapest option.
In a perfect world, you could then rebuild your old motor yourself without any pressure to get it sorted urgently.
Can't find any NEOs under $4000.
Machine shop near me will supply and machine the block to suit Ross pistons, deck and new rod/main bearings for $3500. I just have to pull it out and put it back in.
I'm just concerned I'll need to spend money on the head or something else and it will blow out to a $15k build. But in saying that I wouldn't want to sell the car with the engine in the condition it is.
When you said R33 I didn't think you'd be chasing a NEO.
$3,500 is getting up there as far as machining costs go for a basic build. Have they given you an itemised invoice so you can see where that money is going?
If your building this thing yourself, a basic refresh won't cost you $15k.
Does this sound worth it for $15k AUD in your opinion?
Spool Forged H-Beam Connecting Rods
Ross Forged Pistons 20 thou
Brand New ACL Main/Big End bearings
Factory RB25 oil pump housing with factory gears + Extended  Grub Screwed Crank Collar
Block Acid Dipped, Crank crack tested, block bored and honed to suit pistons, deck block, tap all holes and new welsh plugs
Measure and check tolerances of all engine components
Supertec valve springs and retainers
New valve guides and stem seals
Permaseal MSL-R 87MM headgasket
New front, rear and cam seals
Complete new timing kit w/N1 Water pump.
= $15,000 AUD
(Optional $450 OEM Crank Dampener)
(Optional $350 Fit rear head drain)
(Optional $1100 extended and baffled sump)
If I was going to build something similar to this, I would want to have the oil control issues sorted. Replace the factory oil pump gears with something decent + oil restrictors + extended/baffled sump + breathers from sump to catch can. Unfortunately that build doesn't have any of these issues sorted.
It's your money but I'd say do it properly and spend the extra $$ or just cheap out and do a cheeky refresh, new bearings, MLS gasket, throw in some head and main studs, whatever machining is required/oversized pistons etc.
This isn't an exhaustive list but you get the idea.
There will be a lot of cars hitting this stage after many good years on higher than stock boost.  Rings/bearings with all new hoses and gaskets would be my vote, a new OEM oil pump will also go a long way, without needing to spend big dollars.
Forgive me for asking, what would be the advantages of going new pistons, instead of a new set of OEM rings to suit the existing pistons?  Especially at a manageable power level?
Just throwing a new set of rings in won't change much in the way of blow by if there is excessive cylinder wall wear at 86.0mm pistons. If excessively worn you'd need to go 20 thou over rebore to go to 86.5mm and get a better piston to bore clearance and therefore tighter ring seal.
  • Like 2
  • 1 month later...
I have a probelem low compression engine for high boost, but the WHITES 10l oil pan is filling the heads and going on the track or turbo. Like I dont wannt burn up in a ball of ricky bobby.
I have a spool head drain, but I think between the head drain and the catch can am I forcing oil up? I do not know this stare if leaving oil on the track and them being so mad. 10 liter oil pan, 2 lines into the catch can, and it blows out the vent straight onto the turbo under high revs or full boost. Has a Nitto n1 pump, I cannot trust that they put the proper restrictors in there and are those air / oil seperators any good.  2 lines running directly to catch can, I have no idea if any baffiling has been put in and i highly doubt it. Like to fore the oil back to the back of the head, and into the 10l oil pan. Got me kicked of the track one day long ago, and I need to really fix this. Low comp, massive turbo, 2 step, haltech platnem pro, JEM tuined, Adam. The hoses and catch can are roughted like a little kid and macaroni. that is the first stop, and making the drain back to the sump like 25mm as opposed to 10/15 mm
Its like i answer my own questions.  Spun the clutch centre i hope I havent broken the input shaft.
I Havent taken the rocker covers off, but I think i need a baffle kit and take that catch can to the cold side or run another can. Im running like 90 to 110 Oil pressure PSI, that to me is way to much and nitto have replaced the pump once. is there an adjustment for pressure? Those numbers are cold, she is warm, its like 40 -90 at full boost.
Oil control thread stickied at the top of the forum gives the recipe. Rear head drains don't offer enough. You need to add big direct vents hoses from sump (above oil level) to cam covers, to allow the gases to flow up there, while the oil sneaks back down the original holes in the head/block.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
