Hello everyone I know this topic has been covered a multitude of times but It’s always been plugs and coils plugs and coils, so I bought my c33 about a month ago with an Rb25det series 1 swap car runs idles very well under 5k rpm builds about 0.5 bar of boost but whenever I go WOT after 5k the boost seems to spike to about 1.0 bar of boost causing the car to spit and sputter almost like a limiter/anti lag sound I have recently replaced the coil packs brand new oem and plugs gapped to .8 igniter has been tested and in working condition engine is completely oem from an r33 gtst only thing after market is a Down pipe and a walboro fuel pump any help would be appreciated like I said I know this has been covered but no one seems to include the boost spiking like mine does, thank you
35 minutes ago, Gojira34 said:
No I don’t mean the turbo itself, the ecu can’t handle more than 10psi.
No, not true.
What is true is that the high load high rpm corner of the fuel map is disgustingly rich and the equivalent corner of the ignition map is disgustingly retarded. This means that the engine will drink fuel, make black smoke and no more power as you increase boost above ~ 10 psi. It becomes pointless. And there's nothing you can do to fix it (easily) in an R33 ECU, because there's no easy reprogramming option. R32 and R34 will happily take a Nistune board. R33 (ECU) is the red headed step child that no-one loves.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
