Hi all bare with me on this one.  I have a project I want to have a nudge at but I don’t want to go into to much detail as I’m 99% it hasn’t been done yet. My question is as silly as it sounds is can you change what side the exhaust and intake port are on? eg. change it from exhaust on the right side of the head to left hand side and the same for the intake.
one would assume a custom cam would be needed to get the exhaust and intake lobes in the right place
im asking on here as I don’t have a head or the experience to work it out and collective knowledge always seems to work
 Cheers
lucas
https://www.sau.com.au/forums/topic/482718-rb25det-heads/
I would say that that is a hard no. The shapes and sizes of the intake and exhaust ports are quite different, and you don't necessarily have the room to hog out the (small) exhaust ports to approach the size of the intake ports because the water jackets are quite close to the exhaust port walls.
Then you would have to look at whether it would be possible to fit intake sized valves where the little exhaust valves come from (which would require removing a lot of metal and you'd probably face a similar problem with water jacketing there) and then you'd have to close up the inlet valve holes to take smaller valves.
Just use a 1JZ.
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954666
On 8/9/2021 at 6:14 PM, Dasmbo said:
You can do what i did send your head to Lewis engines and get it machined to suit your purpose it cost me about $4500.00 and it makes one hell of a difference
You swapped the sides of the inlet and exhaust manifolds?
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954682
Yeah, nah sweetheart. We'd be talking about $20+k of work here and it still probably wouldn't work.
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954685
I'll do it for $19,999 and bore it out to a 4L at the same time.
Heres one i did earlier this week
Product Overview: Ford Barra 4.0L Terminated Engine Harness - Haltech
  • Haha 1
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954688
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
