Hello. Having some 'fun' with this new setup on my 1995 S1.5 R33 GTST:
I have a brand new Exedy (extra extra heavy duty) 500kw single plate ceramic clutch kit, new aftermarket throw out bearing + holder, new Exedy spigot with all parts having only 750-1000km on them.
Today while driving I gave it a fairly hard (5000rpm or so) shift from first to second gear and now I can't disengage the clutch. Limped it home in second so the clutch is engaged, but can't get it to move gears whatsoever. Goes through all gears when engine is off.
It made no noise when the clutch stopped working- nothing went bang or made any odd sounds and drove it home fine in second gear.
I checked the pedal adjustment and it's as high as it'll go (most movement of pushrod on slave) and had someone push the pedal down while watching. The slave pushrod moved about 1.5 inches which is apparently the correct amount of movement.
Decided to try and bleed the clutch to rule that out, and now all of a sudden there is no pressure on the pedal- it just falls to the floor and stays there. Tried bleeding master and didn't do anything. A fair bit of air comes out of the slave when bleeding, but continues and gets no better- with no change in pedal.
What on earth is going on? The slave worked fine before opening the bleed valve, now the pushrod won't move, and still obviously can't disengage the clutch as I have a pedal that flops to the floor. Tried compressing and bleeding master 30 times or so with no change. Anyone got any idea what is causing this? Why did the slave suddenly stop, or was this the issue all along?
Cheers everyone! Sorry for the long one.
https://www.sau.com.au/forums/topic/482858-clutch-issues-need-some-advice/
Possibly broken clutch fork pivot, or something just wrong with the clutch.
Anyway I think your box is coming out, as you are somehow not pressing on the clutch pressure plate to disengage.
I think you may have massive air pockets in the damper (the loop next to the chassis rail). Do you have a hand vacuum pump? that might help get fluid down.
Or like the others mentioned, snapped pivot or snapped fork (can happen with super strong pressure plates).
On 9/29/2021 at 4:51 AM, PLYNX said:
 Have you checked the clutch pedal box is intact ?
They are notorious for breaking the spot welds.
Sometimes it can be hard to see as you've got to flip upside down in the foot well to see it !
Thanks for the advice- hsve read about this issue but mine is good, works as it should.
I sadly think this is the case too- based on how sudden it is. I've decided to buy a new OEM slave cylinder just in case but that all appeared to work. The second I opened the breather however it just never bled properly, so maybe a seal in it has gone suddenly. Unlikely but trying before box is out.
Any clue if I can check clutch pivot with a boreascope camera?
you should be able to, remove the slave, remove the rubber and you should be able to stuff those small cameras in there to have a look.
Look, you may have air in the system and your master (not slave) may be passing, but the fact you can see your slave rod moving that much points to something not pressing down on the clutch. This comes back to something like a bent clutch fork or broken fork pivot.
Another thing to check regarding air in the system while you're doing all this,  which has happened to me in the last 2 weeks, is if your booster has had its master cylinder dump clutch fluid into it. My master cylinder seals failed, passed fluid into the booster and got sucked into the engine via the booster vacuum line. It won't be why your not disengaging, but can explain air in the system as slave cylinders very rarely fail.
I believed it may be the slave- it does move but apparently it must move almost the whole way, which it didn't seem to. It was close- but it could be 1-2mm off and that might be all it takes.
If it was the clutch pivot, or even fork for that matter, wouldn't it lose all feeling immediately, as it requires those parts to even move the pedal? Not after opening the slave bleeder? It felt totally normal and made no sounds until I opened the slave cylinder valve.
I suppose this doesn't rule out throw out bearing- I will get a camera in there today and update. Cheers.
On 9/29/2021 at 2:30 PM, BK said:
For your sake I hope it is the slave, but it is very unlikely.
How'd you go with your mangled crank keyway issue ?
I have strong doubt it's the slave too- but for $100 worth a shot. Otherwise tow car then box out. Beginning to hate this car more than I love it haha. 6 weeks on road, 10+ Months off it since ownership. Expensive too...
As for the mangled keyway, bought a used crank, did new ACL race series bearings, oil pump collar, custom single keyway mod, and a ross balancer. Nissan balancers are not made properly and shred the keyways, regardless of bolt torque. It's a design/tolerance fault and I confirmed it by using a micrometer, as well as several OEM balancers- new and used. They never fit properly snug, and rely on bolt tension instead of interference fit! I can't even begin to imagine how many RB series engines are currently driving around with shredded crank snouts as a result- probably a tonne.
Not just oem. I have shredded a keyway with a Ross balancer and Nitto billet crankshaft before - Bolt came loose eventually from crushing the crank washers, and that was at tension to 460nm.
The balancer is not supposed to rely on the key for any sort of load really as that is the bolts job.
20210930_155942.thumb.jpg.3ee4e902177df7d79978cc768d137205.jpg20210930_155935.thumb.jpg.0b1d787ae6e5de85a927b3c5fa327efd.jpg
On 30/09/2021 at 5:19 PM, Dose Pipe Sutututu said:
Since you're changing the slave and rebleeding the entire system - might as well piss off that clutch loop line/damper.
That should be a given really.
  • Like 1
You may have split the clutch fork arm at the pivot ball area  happened to mine when i first upgraded to a higher rated pressure plate. Replaced it with an aftermarket fork arm and pivot ball pin.
Definitely possible too and will have the same effect as snapping the pivot. Did you actually go aftermarket for the fork ? The more common 350z cd009 cast fork with a chromoly pivot is generally the fix for this.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
