Right So got my s3 r33 gtr gearbox to go into my 89 r32 gtr
Gotta do the pull to push conversion...so means draining the oil in the box to take the front plate off ,my understanding is the oil in the box currently is just a small amount of storage oil?
is that the case?
if so is it safe to refill the oil out of the box with the permanent stuff before attaching the transfer case  and getting it on the car or is there a good chance some will spill out the back
during this process? anyone done it this way?
Cheers!
https://www.sau.com.au/forums/topic/483315-gtr-gearbox-install/
And me sorry too, because I followed your lead with brain switched off and I also actually meant "do you really want to go pull clutch?" So my 1st post should look like:
Do you really want to go pull clutch?
Would it not be easier to just drill and tap for the push clutch on the R33 belhousing and use the bits you need from the R32?
Would it not be better to go all modern and concentric, if not wanting to retrofit push clutch?
Not really sure of the order you are thinking, but you need front plate with chosen clutch pivot and xfer case on before you fit it in the car.
Yes you can fill the gearbox and transfer case before you install it, and no you won't lose any (or much) oil if you do it that way
On 2/10/2022 at 11:57 AM, BK said:
If swapping pull to push, remember the Threebond not threadlocker on the input shaft front cover bottom 3 bolts when refitting, or else it will leak.
whats the difference?  is this the stuff?
https://www.repco.co.nz/en/car-care-panel/adhesives-sealants/gasket-cements/threebond-high-temperature-rtv-silicone-liquid-gasket-250gm-grey-1215-250/p/A1130561?kwSearch=threebond
You can use either of the above but preferred is 1207C - the red / brown stuff as it is anti sag, cures faster, has higher temp rating and a superior oil resistance to the ones mentioned. Same stuff used on an RB26 sump.
Never used that CRC one but "appears" to be the 1207C equivalent. Threebond is actually what Nissan sells as their factory RTV from Japan (sourced from Australia).
Some people still use the 1215 grey as it cures slower on sumps, which gives more time when stuffing around fitting it - but it is definitely not as high temp or as oil resistant.
Look harder, it's there. 15 - 20Nm something like that. Seriously though just use a 3/8 drive and tighten it moderately. The sealant on those lower bolts are definitely more important than the exact torque settings.
Transfer case to box torque settings yes, but below was referring to gearbox input shaft front cover
On 10/02/2022 at 7:19 PM, boomtheroom said:
Btw Anyone know what the torque settings are for these cant find anything in the workshop manual...
I'm sure Duncan will have that page handy for exact torque 👍
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
