Do the bottom port test again off car to confirm it definitely passes to the top port, therefore being faulty. If it's got a split diaphragm it'll be obvious when disassembled with a tear in it - It's about the only thing that really fails on them.
Just be careful when you pull the gate apart - remember big spring in there that can send the cover into your face if it flies apart without keeping it compressed on disassembly.
On 16/02/2022 at 4:02 PM, Chereboy said:
Good work, you owe me a carton 😄
That gate diaphragm is exactly the one I linked you to from RHDjapan, so around $150.
HKS part 1499-RA057
  • Like 1
HKS part 1499-RA057
Thanks soo much man, I honestly appreciate it soo damn much. You've been a huge help.
HKS part 1499-RA057
Also just curious on how I would fit it on as the one on my wastegate is round but the online one is squared off, do I just run a knife around the outside of the wastegate after clamping it shut? Thanks again
Nah the rhd one is round - have a good look at all the pictures again - it is curved and just a bit wrinkled up. It'll take shape when installing.
On 18/02/2022 at 8:46 PM, tridentt150v said:
On another tack...10psi sounds a bit low.  You would need to test, but a 14psi would probably suit that turbo and setup a bit better.
Hey mate, so your saying it would be worth my while to have a 14pound spring in there instead of the 7pound one? I'm also going to be tuning the car soon after the diaphragm arrives and I'll probably be pushing close of not a little more than 20psi. I'm also probably just going to have the ECU control the boost so I'll just delete the Blitz one
The general rule is that you do not want to use a spring that is less than half the boost you want to bleed up to, and more spring is generally better than less. So for 20+ psi, you definitely want to be in the 14 psi spring range, rather than 10, and you definitely don't want to be using a 7.
Alright mad, too easy, I'll definitely be sourcing out at least a 14 psi spring setup. Thanks mate
Edited by Chereboy
As your HKS standard gate has no spring preload adjustment on it, I'd say you want the purple spring as it should be about 1.1 bar fitted being that's minimum on the adjustable version  Available springs from RHDjapan attached, although HKS themselves say only the yellow and purple springs are available now and that the original standard gate spring selection is discontinued.
https://www.rhdjapan.com/search/brands/hks/category/turbo-and-na-systems/?q=Spring
Alright, I'm gonna order the purple one tomorrow, I'll see if they can add it to my pending order for the diaphragm as it's apparently going to be sent out on the 21st.
Anyone know how long I'm looking at it taking to reach Sydney NSW? I paid for the DHL shipping and wasn't really sure what it meant by 1-5 days as I'm sure it will take much longer than that to arrive and 5 days will be the 21st when I think they are saying it will be sent out. Thanks guys, don't really understand their shipping system
Screenshot_20220220-201933_Chrome.thumb.jpg.cb4ff0e834a1f1d482a3335fe7b3469e.jpg.
Edited by Chereboy
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
