Just wondering if anyone here has put in a bee*r limiter into there rs4s or any car running an rb25 neo and neo ecu, only asking because from what I’ve found online the s2 an neo pinouts are slightly different? (Correct me if I’m wrong of course) also buying a bee*r but it’s second hand so I don’t think it’ll come with any installation papers so any advice is greatly appreciated!
Apologies if this has been asked and answered before, I haven’t been able to find much out but maybe I’m searching the wrong terms.  Either way definitely looking for any help!
Also if there’s a neo pin out sheet as well as what each wire does for the bee*r because as I stated I believe it won’t be coming with any sort of instructions so info on what each wire means and where it should hopefully go to is extremely appreciated!
still tryna learn as much as I can about rbs and all the little bits with it so even little bits of info is amazing!
Thanks again!
Ron.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/
in the sump, oil pump and head when your stock oil pump grenades from the violent and uncontrolled ignition cuts caused by the Bee R oil pump, valve train destroyer.
I'll be honest with you, if you want bang bangs - get a proper ECU where you can gradually cut ignition and also inject more fuel in to cool down your valve train + make the bangs bangs (if you desire). Those Bee R things are just horrid, absolutely just garbage.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961224
Ahhh fair enough thank you for that! Already got the limiter comin In and don’t plan on using much and do plan on the ecu to do that stuff later on just waiting till I have more parts for the ecu :)
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961229
On 2/16/2022 at 2:53 PM, GTSBoy said:
Listen to this man ^, and the man in the other thread, and also don't start multiple threads on the same website for the same question.
Bee R's are dumb engine destroyers.
Do apologize for making multiple posts kinda thought having it in different sections would be okay cause different people would be seeing it rather than the stag section that sees 1 or 2 posts a month, and yeah as I said don’t plan on using it much cause I don’t plan on blowing the thing but don’t mind hurting the motor a lil bit. (Would like to do a rebuild on it anyways) Do appreciate the info tho cause yah helps me out a lot as I’m still learning!
:) thanks again guys!
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961231
On 2/16/2022 at 3:22 PM, Dose Pipe Sutututu said:
Skip the Bee R, just sell it.
See screen grab below, there's no way a Bee R gives you this kind of control.
Not necessarily looking for control atm because my car is essential stock with a modified exhaust and no cats, just looking for some fun for a moment even if it hurts the motor :)
probably sounds quite dumb and honestly won’t disagree cause it 100% is but I don’t mind, I enjoy doin the stupid things even with the risks, cut up my intake last week and didn’t know if I was gunna get my car on the road for work hahah.
Also probably will sell it, I’m getting it for quite cheap so don’t mind letting it go eventually but do plan on puttin in other cars later on!
also I’m guessing that was pulled from a haltech?? Just wondering because it looks like a very simple interface and trying to decide going haltech or link ecu when the time comes! And yes do plan on the bang bangs with the proper ecu and tune! Just been something I always liked to hear.
also thank you again and prolly will keep thanking y’all for the info, I’m young and dumb so everything helps me learn!
Edited by BiggestRon22
Forgot to add a bit
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961236
Just warning you :)
At the end of the day it's up to you if you want to lunch your motor! If you were wiring this to a 1JZ or 2JZ then it wouldn't be so bad, but everyone knows on this forum aggressive rev limiter & stock RB motors don't mix.
And yes, it's a Haltech - I personally prefer working with them however what you like is very subjective. I prefer the user interface vs. say of a Link. Sure Link has more features, however most of the features most people (including myself) don't really need.
It's like getting a flashy MoTec then not running traction, DBW, inputting telemetry, fuel modelling, etc.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961239
On 2/16/2022 at 4:15 PM, Dose Pipe Sutututu said:
Just warning you :)
Ahhhh fair enough man man thank you for that, yeah I know what you mean the jzs definitely can take more of a beating than the rbs haha, won’t be doin it more than like 10 times over a few months cause yeah proper ecu is the way to go.
yeah I’ve been looking at ecus and can’t really decide, I really like how the haltechs do have the simpler interface and from what I know a lot of tuners know how to tune them as well, but yeah definitely looking at the link mostly because it would be cheaper and does the same thing but mostly just for the price, first pick was a haltech so maybe I’ll bite the bullet and save up a little bit more so if I need to go in there and do a small tweak it’s not like opening Pandora’s box yknow hahah.
also I’m looking at the plug and play ecus from link and haltech, I’m guessing the platinum pro would do just fine even tho they are older, not completely looking for the launch control and the other trinkets the elite 2000/2500 has but with that said the link I believe has those features for the same price. Guessing it’s more which one I want more but wouldn’t mind getting some extra options on the three ecus (again it’d be the haltech platinum pro/elite2000 or the link g4x)
as I keep saying thank you for all the info man!
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961240
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
