Just now, Meap said:
I know you also commented on my post, but you didn't post this picture there. I don't use that spacer, just put a paper gasket between the booster and the firewall and you're good to go!
Thank you so much - appreciate it!
  • Like 1
Few questions - just want to make sure i did it right. @Meap @McGarryR32
The “U” the clevis pin goes through is shorter on the 35 but can be swapped over for your original one as they’re the same thread.  (regarding this) do you notice your brake pedal sitting a bit lower than the stock height? i had to adjust the switch lower so that its touching. i have adjusted the bolt to the end of the U but the pedal is a bit lower - is it the same for you guys as well?
image.thumb.png.e5463da0ead8fa611632255e5908b885.pngimage.thumb.png.fb564b7dde92b57ad98b274426e7bbcf.png
  • 1 year later...
does anyone know the specs of the R35 master cylinder, rear ratio and knee point?
the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting..
the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
  • 10 months later...
How did you get on with this?  Did you end up fitting a prop valve?
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
