Hi all, thanks for letting me join group. Some help here would he much appreciated. My son bought he's 1st R31 and we have no Speedo working. I have attached Pics if what we discovered yesterday. It's a conversation to manual.
Cheers Matt
https://www.sau.com.au/forums/topic/483900-speedo-not-working-1990-r31/
Welcome to the forums Matt, and well done to your son for making an excellent choice in 1st car.
I am not familiar with R31 setups, but R32 used a mechanical speedo drive from the gearbox to the dash and I suspect R31 might as well. Is there another connection further back on the gearbox on the passenger side? Of course this may never have been done properly when the manual swap was done.
Here's an RP71C #2 (photo taken from this very site) showing an electronic speed sender.
http://i68.photobucket.com/albums/i30/0t1/more/IMG_0296.jpg
I'm not at all sure what that 3pin connector is all about - unless it is the wiring for the reverse and neutral switches brought together. It's certainly not the usual connector for the speed sensor.
Anyway - I'm pretty sure that the R31a used a mechanical speedo drive, and this gearbox, being an R33 turbo box (the best thing to have, by the way) usually has an electronic speed sender, as in the image above. So - you cannot make it work without building a mechanical speedo drive. You will need the speedo drive from a Navara from the same period to do this. I think you have to use the gear from your electronic drive to get the right ratio (Navara being different). There are howtos on here and elsewhere on the net, although I've never actually seen one as I didn't have to do mine - my bro'-in-law built the drive for me.
Cheers mate. Will check to see if cable is actually in the back of the dash tonight and we'll take it from there. Appreciate your feedback a lot.
Hi Matt, I have a RP71C#2 gearbox in my car and it is the twin synchro RB20det gearbox from the r32 Skyline, my car uses a mechanical drive speedo which I recently replaced the speedo pinion drive as it disintegrated and jammed up and would not let me select 5th gear.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
